Grow Vegetables Indoors Over Winter
Intro: Grow Vegetables Indoors Over Winter
During winter it's hard to grow your own veggies without them freezing to death. We still want our fresh vegetables but don't have a glass house to put them in, so I decided to build myself an indoor window box.
What you need:
Square section tin spouting
Untreated wood about 20mm thick
Sealant
Wood screws
Rubber feet
What you need:
Sealant
Wood screws
Rubber feet
STEP 1: Materials
I went along to a local building supply recycler and found a length of tin spouting. The spouting was about 130mm square, 1800mm long and made from colour steel which is tin with a baked on colour coating. The spouting cost me NZ $8.00.
After a look thru my wood pile I found some untreated 150x150x20mm timber for the ends of my window box.
STEP 2: Assembly
Measure the inside of the spouting, across the bottom and up the sides.
Mark and cut two pieces of your untreated wood so they fit snugly in the ends of the spouting.
Pre-drill the spouting about 10mm in from the edge and put a bead of sealant along the edge. The sealant is simply to stop water leaking out around the ends onto my window sills.
Use wood screws to secure the ends of your window box on.
I used four self adhesive rubber feet on the bottom of the window box so the screws on the bottom dont scratch the window sill.
STEP 3: All Done
Now its time to fill your window box with soil and plant some vegetables. I put my window box in a nice sunny window, after a few days I could see the lettuces had grown!!
Happy growing.
Happy growing.
43 Comments
MojtabaT 7 years ago
Good idea. I,ll make one, if I ever divorce my wife.
GreendeaG 8 years ago
Nice job like the idea , have a look to my hydroponics garden www.green-dea.com
elbadrunos 9 years ago
great idea !!! May I ask. which direction that the window faces ? west or east or another ? And how long the estimate time of plants get the sunlight ? Thank you
tokala 9 years ago
mwhite30 11 years ago
Kind regards
Mal
croemita 14 years ago
tokala 12 years ago
Number5Alive 12 years ago
Additionally, this needs to be in a South-Facing window with zero shade from neighbors or trees.
frogmama 14 years ago
Isn't it nice to have fresh veggies growing in the winter?! Late last winter I grew peas just to enjoy watching something GROW in the winter.
reichert99 13 years ago
frogmama 12 years ago
I think the biggest problem with any indoor flowering plant/vegetable is cross-polination. I made a point to shuffle the plants with my hands when they were flowering to hopefully help in that. (or use a paintbrush) It's not really sturdy enough (at least mine, at nearly 5 feet) to carry outside for the day, but you could try that or simply take the screen off the window for a few hours. Just make sure you have a fly swatter around!
dkiehl 12 years ago
then give the flowers a spritz ( follow directions on product ) Note: Fruit / veggies will be seedless! Great for tomatoes used for juice or sauce
dkiehl 12 years ago
To catch the little buggers find a bottle or use an empty plastic soda bottle ( clear is best so you can see how many you trapped) and pour in some vinegar 2 tablespoons is enough but enough to cover the bottom is better. Roll a piece of paper to make a funnel so that you have a hole that is pencil diameter or smaller. ( top diameter the larger the better but large enough so that it will not fall into your bottle) Use tape to secure your funnel together and then tape the funnel to the top of the bottle. Set your trap near your soil.. Happy hunting
MrChuII 12 years ago
jrmurch 13 years ago
jpivot 14 years ago
WILL62 14 years ago
If you put your plants as close as possible to the light source,"GROW LIGHT" or shoplight, I mean 1/4" away that will help greatly...the shoplight won't give off any heat to hurt your little plants...grab it and find out, its cool to the touch barely warm, I let them touch the lights, also if you want strong stems turn a fan on low or medium and let it gently stir the stems in turn they will become strong and stocky....try it ok!
jpivot 14 years ago
WILL62 13 years ago
jpivot 13 years ago
