Guard Dog Burglar Alarm!
Intro: Guard Dog Burglar Alarm!
Turn your doorbell into a vicious guard dog alarm! Watch the video then buiild your own and protect your home and family.
STEP 1: What You Need
STEP 2: Build the Circuit
Following the schematic, make the connections between the rectifier, diode and relay. You will need to bench test your relay to determine the input and output connections as well as the )+) and (-) connections on the rectifier.
You will end up with 4 open wires. Two coming from the relay and 2 coming from the rectifier.
NOTE: My doorbell circuit generated 18V from the transformer with 13.5 volts AC at the doorbell ringer. Your doorbell voltages may be different and the circuit may have to be designed specifically for your voltages.
STEP 3: Finish the Connections
Remove the playback button on the recording module by bending back the two tabs on the back.
Solder the two connections coming from the rectifier to the playback contacts.
Pick the audio cable of your choosing (I used a mini female connector on a length of wire with bare leads) and solder the two connections to the speaker terminals on the recording module. This will allow you to directly input audio to the recording module.
STEP 4: Load Your Sound Effect
Run the sound effect of your choice and press the recording module button to record the sound to the module. I used this one and edited it a bit.
STEP 5: Make the Final Connections
Plug an audio cable into the cable your soldered to the recording module. This is also the output as well as the input. Connect it to the Wireless Transmitter. Connect the two wires from the relay to your two contacts on your doorbell. Connect the output of the Wireless Receiver to your stereo system. Connect a 9 V battery to the recording module and your Guard Dog Burglar Alarm is finished!
When the doorbell is pressed, the recording module will playback the sound effect and send it to your stereo system. You can adjust the audio by walking outside to see what sounds best.
I hope you enjoyed this Instructable!
43 Comments
SteveA4 9 years ago
Does this make sense?
SteveA4 9 years ago
This is a great project. Two issues that I picked up, maybe you can help to correct this. The first issue is that the two leads from the rectifier first showed being connected to the doorbell, and then shown somewhere else as being connected to the recording device. So, which one is right? I vote the doorbell leads go to the 12V relay and not to the playback device.
Also, where does the 2.4 GHz Audio/Video transmitter connects? I would have thought at the playback connector , but does that mean these leads at T'd into the two rectifier leads?
With these two clarifications, this is a simple yet effective device.
Thanks
Steve
goldenshuttle 9 years ago
great idea; indeed no need even a microcontroller. However it works only if bell is pressed. one can try adding a PIR sensor which triggers the recorder if anyone comes close to door..of course home owners won't be worried about it and they can turn it off after they enter the place. great work Mr.Kipkay..please keep posting
cjs1298 10 years ago
jrigvd 11 years ago
techboy411 11 years ago
could this wake a PC?
sk8r4life 14 years ago
georion 12 years ago
Kipkay 14 years ago
Default117 14 years ago
ElvenChild 13 years ago
ARJOON 14 years ago
Kasm279 13 years ago
cupnoodles2 14 years ago
DJ Radio 14 years ago
Bartboy 14 years ago
Mr. Squishy 14 years ago
Squid Tamer 14 years ago
mhkabir 14 years ago
jimmytvf 14 years ago
