Guitar Pick Holder
Intro: Guitar Pick Holder
(sorry for my bad english... i'm not a native speaker)
This is my first instructable... and I forgot to take pictures while I was doing it, but that's what Paint is for :-)
soooo... I'm going to try to show you how I made my Guitar Pick Holder for a friends birthday (last minute Present)
It will take... half an hour or a hour... It depends on your skill
and sorry, but i measure in meters and centimeters :-)
STEP 1: What You'll Need
I've got this idea while I was roaming through the lokal hardware store and I thaught THIS yould work:
2 springs
leather
woodscrews with rings on it (sorry... i don't know what they are called)
profiled wood (half cylinder, or I used quarter cylinder, it was cheaper ^^ radius of the circle 2 cm)
Saw
Scissors
Glue (I used Pattex)
STEP 2: Cut the Wood
If you are using quarter cylinders you cut 2x 7cm pieces of the wood profile and glue them together properly.
If you are using semi-cylinders, congratulations! you just cut once! :-P
If you are holding your 7 cm semi cylinder in hands, continue with step 3
STEP 3: Prepare the Leather
so, you need three pieces of leather:
2 for the ends, and one for the biiig surface :-)
soooo for the 2 end pieces, you cut a circle with 1 cm more as the diameter as the semi cylinder
and you cut that IN HALF
for the big piece you cut a 7cm x 17 cm (the 17 cm is a little bit more to be sure)
STEP 4: Glueing :-)
you glue the 2 small pieces on the sides
be sure that the straight lines are matching! the extra leather on the circular side is bent up and glued there
if you don't like the look of the straight line of the smaller pieces that presses through the big leather strip when you glue it on, just cut it (Razorblade) round for a smoother look.
for the big piece, you start glueing in the middle of the straight side and glue the way around
when you reach the beginning of the leather strip, just lay the end of it over the beginning and cut off whats too much
STEP 5: Screw the Screws
where you screw the screws is a matter of your personal sight on art and what kind of spring you use^^
but i think when you approximately screw them where they are in the picture it looks fine
when you screwed them in... just click in the spring... and you are finished!
i hope you enjoyed this instructable (and i hope you understood everything )
19 Comments
wobbler 8 years ago
Very clever idea!
gingerkwall 9 years ago
Springs are easy to make with some wire and pliers. If you don't have any wire, buy 18 gauge galvanized stainless steel wire at the hardware store (usually found with picture hanging supplies $1-$4) and wrap it around a pen or anything else round. Use a pair of pliers to shape the ends.
bassdale 11 years ago
fordf150man 12 years ago
babanajoe 12 years ago
trustr 12 years ago
beader1986 12 years ago
azbo1 12 years ago
mamapop 12 years ago
trustr 12 years ago
The Leather... I went to our local leather factory and asked for scrap leather... but you can get Leather anywhere where Shoes are made or where a leather-couch gets its skin :-)
OR you go to a second hand shop, get a cheap leather jacket and use that.
the wood... I got mine in the lokal hardware store. (~2€ per Meter) but I think you can look for it in stores that sell stuff for modelmaking or you ask a friend with a bench saw if he could cut a full circle in half :-)
I hope that helps you out
splazem 12 years ago
jmosley1 12 years ago
I would buy one from you
Iridium7 12 years ago
barnsey_d 12 years ago
should manke a good letter holder too.
DWordDtour 12 years ago
trustr 12 years ago
gavox 12 years ago
trodriguez 12 years ago
P.S.: Your English is perfectly understandable.
trustr 12 years ago
