Guitar Tuner Arduino
Intro: Guitar Tuner Arduino
The Guitar Tuner is a simple tuner that you build using Arduino. Using the electret microphone it can find the frequency of the Low e string, A, D,G,B, and the high E string. Using the frequencies the electret microphone will tell the display to tell you if your off-tune.
STEP 1: Tinkercad and Connections
The Tinkercad above will show you how to connect each wire (NOTE: I used a photoresistor instead of an electret microphone, but it works the same way). Also, I will write down below where to connect each pin:
VSS to GND
VDD to 5V
V0 to GND
RS to 2
RW to GND
E to 7
D4 to 8
D5 to 9
D6 to 10
D7 to 11
LED Anode to 5V
LED Cathode to 5V
AND YOUR ELECTRET MICROPHONE:
Terminal 1/Left part to 5V
Terminal 2/Right part to 0
STEP 2: Code
#include "arduinoFFT.h" #define SAMPLES 128 //SAMPLES-pt FFT. Must be a base 2 number. Max 128 for Arduino Uno. #define SAMPLING_FREQUENCY 2048 //Ts = Based on Nyquist, must be 2 times the highest expected frequency. arduinoFFT FFT = arduinoFFT(); unsigned int samplingPeriod; unsigned long microSeconds; double vReal[SAMPLES]; //create vector of size SAMPLES to hold real values double vImag[SAMPLES]; //create vector of size SAMPLES to hold imaginary values //LCD Display #include <LiquidCrystal.h> const byte LCD_D7 = 11; const byte LCD_D6 = 10; const byte LCD_D5 = 9; const byte LCD_D4 = 8; const byte LCD_E = 7; const byte LCD_RS = 2 ; LiquidCrystal Lcd(LCD_RS, LCD_E, LCD_D4, LCD_D5, LCD_D6, LCD_D7); const byte LCD_WIDTH = 16; const byte LCD_HEIGHT = 2; void setup() { Serial.begin(115200); //Baud rate for the Serial Monitor samplingPeriod = round(1000000*(1.0/SAMPLING_FREQUENCY)); //Period in microseconds //LCD Lcd.begin(LCD_WIDTH, LCD_HEIGHT); Lcd.print("Starting..."); delay(2500); Lcd.clear(); } void loop() { /*Sample SAMPLES times*/ for(int i=0; i<SAMPLES; i++) { microSeconds = micros(); //Returns the number of microseconds since the Arduino board began running the current script. vReal[i] = analogRead(0); //Reads the value from analog pin 0 (A0), quantize it and save it as a real term. vImag[i] = 0; //Makes imaginary term 0 always /*remaining wait time between samples if necessary*/ while(micros() < (microSeconds + samplingPeriod)) { //do nothing } } /*Perform FFT on samples*/ FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD); FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD); FFT.ComplexToMagnitude(vReal, vImag, SAMPLES); /*Find peak frequency and print peak*/ double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY); Serial.println(peak); //Print out the most dominant frequency. /*Script stops here. Hardware reset required.*/ while (1); //do one time //LOW E STRING if(peak>83.5 && peak<92) { Lcd.print("Your E string is too high."); delay (2000); Lcd.clear(); } if(peak<82){ Lcd.print("Your E string is too low."); delay (2000); Lcd.clear(); } if(peak<=83 && peak>=82){ Lcd.print("E string is in tune."); delay (2000); Lcd.clear(); } //A STRING if(peak>110.5 && peak<128){ Lcd.print("Your A string is too high."); delay (2000); Lcd.clear(); } if(peak<109.5 && peak>93){ Lcd.print("Your A string is too low."); delay (2000); Lcd.clear(); } if(peak<=110 && peak>=109){ Lcd.print("A string is in tune."); delay (2000); Lcd.clear(); } //D STRING if(peak>147.5 && peak<170){ Lcd.print("Your D string is too high."); delay (2000); Lcd.clear(); } if(peak<145 && peak>128.5){ Lcd.print("Your D string is too low"); delay (2000); Lcd.clear(); } if(peak<=146 && peak>=147){ Lcd.print("D string is in tune."); delay (2000); Lcd.clear(); } //G STRING if(peak>197 && peak<222){ Lcd.print("Your G string is too high."); delay (2000); Lcd.clear(); } if(peak<196 && peak>171){ Lcd.print("Your G string is too low."); delay (2000); Lcd.clear(); } if(peak<=197 && peak>=196){ Lcd.print("G string is in tune."); delay (2000); Lcd.clear(); } //B STRING if(peak>248 && peak<288){ Lcd.print("Your B string is too high."); delay (2000); Lcd.clear(); } if(peak<247 && peak>223){ Lcd.print("Your B string is too low."); delay (2000); Lcd.clear(); } if(peak<= 248 && peak>= 247){ Lcd.print("B string in tune."); delay (2000); Lcd.clear(); } //HIGH E STRING if(peak>331.5 && peak< 400){ Lcd.print("Your high E string is too high."); delay (2000); Lcd.clear(); } if(peak<329 && peak>289){ Lcd.print("Your high E string is too low."); delay (2000); Lcd.clear(); } if(peak<=331 && peak>=330 ){ Lcd.print("Your high E string is in tune."); delay (2000); Lcd.clear(); } }
Penolopy Bulnick 2 years ago
