Introduction: Gum Wrapper Cross
How to make a small Cross and stand using just 5 gum wrappers.
A small rounded object the size of a nickel can be used to shape the stand.
Step 1: Make Sticks
Lay the wrapper out flat with the serrated edges facing up. Make sure the little flaps at the ends are unfolded all the way.
Fold in half lengthwise. Try to make the fold as exact as possible.
Step 2: Fold 2nd and Third Time.
Keep folding in half a couple more times lengthwise. When you get to where you can't fold it, crease it down the middle with your thumbnail.
Step 3: Roll the Stick
Fold around the crease as best you can. Then roll the piece between your thumb and fingers to produce a cylindrical stick made of alumninum.
This is a basic building block for my gum wrapper creations. It's fairly easy to do while you're watching TV (at least it keeps you doing SOMETHING).
You'll need at least 5 sticks for this project. Get busy repeating these first 3 steps.
Step 4: Measure the Attachments for the Stand
Make a fold about 1/4 th of the length of the stick. This will allow enough length to attach to the bottom of the cross. You can use a ruler, fold another piece into fouths as a measure, or just eyeball it.
Measure down about half-again as much and make another mark (sorry, the photo shows two whole segments, not 1 and 1/2). It's not an exact science so I usually just eyeball that second half segment as well.
Step 5: Fold the Semi-circle for the Stand
Fold a 90 degree angle on the stick at the first segment. Then fold another 90 degree at the second segment so that it's perpendicular to the first one. Find something that you can wrap the stick around that is the diameter if the one segment (1/4 of the wrapper length). Use whatever you find to make a semi-circle with the attachment piece upright in the center.
Repeat these last two steps for the other half of the stand.
Step 6: Attach the Stand to the Upright
Bring the two sides of the stand together with the two upright pieces just opposite each other. The smaller segments should form a diameter wih the curved portions forming a circle.
Take one of the straight sticks and place it between the two upright pieces in the middle of the circle. Bend the two upright pieces around and wrap all the way around it's base. It's probably going to get out of shape now, but just make it so the straight stick is able to stand fairly straight up.
This is the toughest part of this one.
Step 7: Create Cross Members
Take another straight stick and hold it perpendicular to another one. Wrap about 2/3 of the length around the stick in a tight spiral. You need to make two of these - one for each arm of the cross.
Just make sure you make the arms the same length and use up enough of the stick so they aren't to long. Each cross member will look the middle piece below.
Tip:
Once you create the first one, you may need to use the upright of the cross to make the spiral wrap on the second one. I usually have spare sticks around and use them for these spiral folds. It cuts down on the handling of the other pieces I'm putting together.
Tip:
Step 8: Assemble the Cross Members
Slide one of the cross members down the upright with the spiral lower than the outstretched arm. It should be down about a quarter of the way. It should stay put. If it slips, tighten up the spiral by twisting it some more.
Step 9: Finish With the Top Cross Member
Slide the final cross member down the upright with the spiral being above the outstretched arm. Move it down so it's right on top of the first cross member. Adjust the arms to they are in opposite directions.
God Bless,
Amen.
God Bless,
Amen.
