Introduction: HARD DISK COVER USING LEFTOVER WEDDING CARD
season of indian weddings as it is ...u can use it to make a complete diy hard disk cover or almost any cover
Step 1: WHAT ALL U NEED
*scisors
*scale
*glue
*pencil&eraser
*of course a wedding card
i had a one with cardboard material inside.... so it made it a lot easier...if its a simple sheet get an adition cardboard
Step 2: SEPERATE
**separate the cardboard and inner and outer coverings form the card
**it will end up in three sheets or layers
Step 3: LAYERS
***i have now taken two layers ..one of cardboard and other of the outer covering
Step 4: MEASUREMENTS
***now take the measurements of the disk or whatever you are making
***take two separate sheets of outer layer and draw the measurements
***take some extra space of 1cm and cut as shown in the image along the extra 1cm u left
Step 5: FINALE
**now stick the cardboard on to the first layer which is cut according to the ACTUAL measurements of the disk(and the cable)(excluding the extra 1cm)
***i have also added a flap which i got from the inner layer
*** stick together the two halves using the extra space u left using a gum
Step 6: VOILA!!!
use a double sided tape to keep the flap in place and enjoy your diy
Homemade Gifts Contest 2015
Leftovers Challenge
Leftovers Challenge
