Introduction: HC - 06 ( Slave Module ) Changing " NAME " Without Use " Monitor Serial Arduino " ...that " Works Easily " : Faultless Way !
After " Long Time " trying Changing Name onto HC - 06 ( slave Module ) , using " serial monitor of the Arduino , without " Sucess " , I found another easy way and im Sharing now !
Have Fun Buddies !
Step 1: All List : Arduino UNO , HC - 06 (Module - Slave) , 4 Wires ( Male to Female ).
Step 2: Conections :
- Module - TX pin -- Arduino RX pin
- Module - RX pin -- Arduino TX pin
- Module - GND pin -- Arduino GND pin
- Module - PWR pin -- Arduino 12 ( Digital ) pin ( The magical Works here ! )
Step 3: Strech !
- After upload the Stretcher onto Arduino UNO
- Hook-up the Wires ( 4 - four )
- Remind ! Cross the TX - RX pin between Both ( Module x Arduino )
- Press the Resset Button of Arduino ...Wait till ( TX ) pin of Arduino Stop Blinking
- That´s all after the Main Led ( Arduino Relight = ON stedy )
- Congrats Well Done !
Microcontroller Contest 2017
1 Person Made This Project!
- tytower made it!
4 Comments
4 years ago
Doesn't work...
5 years ago
I got this message but it does not show here for some reason. Don't understand what you are saying?
[quote]Ok looks very usefull ! !However some units can´t reach the ( AT - Comands )
through ( serial monitor of the Arduino ) notwithstanding , repling some " commands , they never " change by Serial monitor " , the NAME , PIN ( PSWD)... like this way it was just to help when it occur ...
anyway tjs a lot ![/quote]
5 years ago
This use of the arduino high pin drops the voltage to about 4.2V which operates the 3.3 V BT but is rather dubious . I'd put a diode in there too to drop it another half volt.
See this one as well.
https://www.instructables.com/id/AT-command-mode-of-HC-05-Bluetooth-module/
5 years ago
anyway tjs a lot !
