Introduction: HOME MADE FLAVORED COFFEE CREAMERS
DO YOU LIKE FRENCH VANILLA CREAMER? HOW ABOUT HAZELNUT? HERE IS THE EASIEST WAY TO MAKE YOUR OWN AND SAVE A TON OF MONEY!
ALL YOU NEED IS:
1/2 GALLON OF CREAM (IN THE REFRIGERATED DAIRY SECTION-YOU CAN USE LOW OR NON-FAT IF YOU CHOOSE.)
I BOTTLE OF FLAVORED SYRUP (OR IF YOU CANT FIND THAT, USE CORN SYRUP MIXED WITH FLAVOR EXTRACTS)
1 CONTAINER TO STORE CREAMER(I SAVED AN OLD INTERNATIONAL HOUSE BOTTLE)
*THIS IS ENOUGH CREAM TO MAKE 2 CONTAINERS-IF YOU WOULD NOT USE IT BEFORE IT SPOILS, I SUGGEST USING A QT OR 1/2 QT OF CREAM. THE FLAVORED SYRUP WILL KEEP IN THE FRIDGE FOR UP TO A YEAR AND IS USUALLY FOUND IN THE COFFEE SECTION UNDER THE COFFEE BLENDS.
ALL YOU NEED IS:
Step 1:
CLEAN AND ALLOW YOUR CREAMER BOTTLE TO AIR DRY COMPLEATLY.
IF YOU ARE MAKING YOUR OWN SYRUP, I SUGGEST MAKING IT NOW AND STORING IN A PLASTIC OR GLASS BOTTLE UNTIL THE NEXT STEP. ITS KIND OF MESSY AND EASIER TO CLEAN UP WHILE YOUR BOTTLE IS DRYING.
Step 2:
IN A MIXING BOWL MIX 2 1/2 CUPS CREAM WITH 1/2 CUP FLAVORED SYRUP
(IF YOU COULDNT FIND FLAVORED SYRUP YOU CAN SUBSTITUTE 1/4 CUPS CORN SYRUP AND 2-4 TABLE SPOONS OF YOUR DESIRED EXTRACT) (*IF YOU ARE USING YOUR OWN SYRUP NOTE THAT CORN SYRUP IS VERY SUGARY. YOU CAN USE LESS SYRUP AND SUBSTITUTE CREAM IN ITS PLACE JUST USE MORE EXTRACT)
Step 3:
MIX THE INGREDIENTS THOURELY. POUR INTO YOUR DESIRED CREAMER CONTAINER AND CHILL. USE WHEN YOU WANT A NICE CUP OF FLAVORED COFFEE WITH OUT PAYING THE PRICE!
LOOK FOR THE BIG PUMP IF YOU NEED TO MAKE ALOT OR IF YOU USE ALOT-ALSO ITS EASY DISPENSE!
***FOR THE AMOUNT YOU WILL PAY FOR THE INGREDIENTS, YOU WILL BE ABLE TO MAKE 4X THE AMOUNT OF CREAMER YOU WOULD GET FOR A NAME OR EVEN STORE BRAND OF THE PRE MIXED CREAMERS***
Step 4:
***DO NOT FREEZE CREAMER! IT WILL SEPERATE AND NOT TASTE SO GOOD!***
