Introduction: Half Up-do
Doing half-up-dos is a fun and easy skill to learn. You can search the internet and find a lot of amazing and different half-up-dos. However, many of those half-up-dos are very difficult to do. So in these step-by-step instructions, you will be learning how to do an easy half-up-do.
  • comb
  • scissors
  • rubber bands
  • clips
  • edge gel
  • straightener
  • synthetic hair
Step 1: Curl Hair
Using your flatiron, curl the entire head.
Step 2: Section and Braid
Sectioning the hair down the middle of the head mid-way, then before you start braiding, add edge gel to the hair and then you start the dutch braid. Add in your synthetic hair to the dutch braid to the top of the head, and then stop adding the hair in and braid it till a few inches before the hair ends(cut off any excess hair).
Step 3: Start the Updo
Grab two sections both from under the two braids and tie them off with a rubber band, twist it around and loop it through itself. Once you get further down use the hair from the top and down to the length of the braid.
Step 4: Continue the Half-Up-do
Take out one of the twists towards the bottom and tie the braids to it. Twist it towards the head and tuck the twists into a couple of bottom braids. You can tease the hair, only a LITTLE bit, and tuck it in as much as possible. And you can fix any of the little mess ups with the hair.
Step 5: Finished
Enjoy your new amazing half-up-do.
