Introduction: Halloween Rice Krispie Treats
What better way to celebrate Halloween than with delicious Rice Krispie Treats covered in Jell-O flavored Marshmallow Fondant! Check out how to make these adorable pumpkins, ghosts, skulls and kitty cats.
Step 1: Supplies
It doesn't really very, but here is what you need.
Edible:
Edible:
- Rice Krispie Treat = Rice Krispies Butter Marshamllows
- Marshmallow Fondant (MMF) = Marshmallows Water Powdered Sugar (optional jell-o for color and flavoring)
- Corn Syrup for "glue"
- Food coloring
(What I used: black for cats and decorations for skulls, ghosts, and pumpkins; orange for pumpkins; green for pumpkin decorations) (You can use liquid or gel coloring. If you use liquid, I usually use that as a substitute for some of my water when I melt the marshmallows.)
- Crisco or Non Stick Spray (I use the spray) - to put on your hands while working with the rice krispie mix. It helps stop the marshmellowy mess from completely covering your hands.
- Pot for making Rice Krispie Mix
- Bowl
for Rice Krispie Mix (if you leave it in the metal pot it will stick like crazy, I use nonstick spray on a glass or plastic bowl and transfer the mix while I'm shaping my treats)
- Silpat Mat
or Similar Alternative
(like usual, these are AWESOME when working with MMF)
- Halloween Cookie Cutters
(I got these because there was a variety of shapes in one package and they were smaller than what I usually use; it seems like all my holiday rice krispie treats have been getting too big, these are perfect for personal sized snacks.)
- Pizza Cutter
- everyone has one of these, but it is really nice to have for cutting strips with fondant
- Piping tips
or something similar you can use to cut out small circles - I've used these for various decorating projects and they are just nice to have :)
Step 2: Make Halloween Treats
Pick out your shapes! I decided I had to do a pumpkin. I also wanted to try the ghost, skull and the cat while I was at it. After doing this I would strongly suggest, if you are using small cookie cutters like me, to not do ones with little bits on it. For example: it was hard to fill in the little ghost tail. Not impossible, just hard. I would still do the ones I did, but doing the little kitty ears, and making sure you could tell what they actually were, was hard.
Steps:
Steps:
- Move rice krispie mix to another bowl. I sprayed a glass mixing bowl with non stick spray and poured mine in there. I say to move the mix, because the first time I did this I left it in the pot I made it in and by the time I got to the bottom it would not come off the pot. Real pain that was.
- Spray your cookie cutters with non stick spray. I did this a little late and I think that was why the mix would stick. Also, plastic might work better here than metal cookie cutters.
- Smash the krispie mix into the cookie cutters. And when I say smash, I mean smash. You want to hear the krispie crunch as you smush them in. This gives them a nice strong and defined shape.
- Set them aside to harden up a bit before moving on.
Step 3: Clean Up the Mess You Made...
when you dropped the box of rice krispies.
I know, sad day, sweep it up and you'll be fine.
It is hard to hold that big box with one hand while measuring out 6 cups of rice krispies.
Step 4: Cover Piece by Piece Or...
I don't really like this method, but it is an option.
- Take out your pizza cutter and cut out strips of your MMF that is roughly the thickness of the rice krispie treat shape.
- Then use the cookie cutter that matches your shape (in this instance, pumpkin) and cut it out in MMF.
- Wrap the strip around the side of the treat. If there is extra, fold it over the top as show in the pictures.
- Stick the cut out fondant right on top. This does the trick, but doesn't look nice in my opinion.
Step 5: Fully Cover
This is the method I usually use that gives the best results. It is very time consuming though.
- Roll out your MMF.
- Lay it over the top of the rice krispie treat you want to cover.
- If the fondant is soft it will mold nicely to the treat. Just ease the the fondant over the edges until you have covered the top and sides of the treat.
- Cut around the bottom edge. If you have extra hanging down, just smooth it over the bottom of the treat.
- Repeat for all the treats!
Step 6: Decorate
Time to decorate them! Us a decorating paint brush to brush on corn syrup to use as clue for all your little pieces.
Pumpkin (2 options)
Pumpkin (2 options)
- Traditional Pumpkin:
- Roll out some green and cut out a couple small circles of green using a decorating tip.
- Smush the circles a bit to give them more of an oval or diamond shape.
- Arrange the rolled out piece as a vine and put your little oval leaves on the vine.
- Jack O' Lantern:
- Cut out a couple circles for leaves. (you don't have to, but they look cute)
- Cut out larger circles from the black using a larger decorating tip.
- Smush the larger circles to look like triangles and arrange them as eyes and a nose.
- You can get more complex and creative! Go crazy! I would love to see what people do!
- Cut out 2 larger circles and a few smaller ones using the decorating tips.
- Put the big circles on as eyes.
- Put on the smaller circles as teeth and kind of smush them up against each other to make them more oval.
- Cut out three small circles using the tips.
- Arrange them as eyes and a mouth.
Step 7: Have Fun
Eat up! You can see I just cut out shapes for all those colored ones. It is a nice easy way to do it if you don't have time to completely decorate them all.
Hope you enjoy!
Finalist in the
2013 Autodesk Halloween Contest
Halloween Food Contest
7 Comments
8 years ago
can you make them with anything else instead of jello because I am Irish and we don't have jello here?!
Reply 6 years ago
Sorry for the 2 year delay in replying :( Yes, just leave the jello out and it will be plan marshmallow, or you can use an extract (like vanilla, or lemon, or raspberry) to flavor it.
8 years ago
I make speciality cakes on the side. I've tried every kind of foundant recipe possible. This one is the best I've ever tried. U have made my cake decorating a lot better. Not to mention the taste of them. This is the best foundant ever
8 years ago on Introduction
Yum!!!! So cute! The only thing that would be a pain is the fondant..but worth it I'm sure....they look so good!
Yum these look adorable!
They are so cute--Love to see how you use your fabulous fondant! :)
Thank you :)
