Master Chief Halo Armor.
Intro: Master Chief Halo Armor.
This indestructable is on making halo armor.
MATERIALS:
Lots of cardstock
glue and staples
lots of pading black is probably the best color
motorcycle visor
reference pics
dobble sided tape
LEDs optional
primer, spray paint
velcro
computer
printer
fiber glass mat 3 yards
lots of straps
MATERIALS:
Lots of cardstock
glue and staples
motorcycle visor
reference pics
dobble sided tape
LEDs optional
primer, spray paint
velcro
computer
printer
lots of straps
STEP 1: 1 Getting Started
Go to this link and download Pepakura you will need it to print the armor layout.
http://www.tamasoft.co.jp/pepakura-en/
Then go to this link to chose what parts and weapons you want.
http://halocostuming.wikia.com/wiki/Pepakura_File_Index
THIS IS IMPORTANT
On Desktop make a separate folder named Halo Armor
When saving the files be sure to save then to the Halo Armor folder and BE SURE TO RENAME THE FILES TO WHAT PART OF ARMOR THEY ARE...... TRUST ME
Also go to this link to chose reference pics. Print at least 10 on 2-3 pieces of paper.
http://images.google.com/images?hl=en&q=master+chief&gbv=2&aq=0&oq=mast
http://images.google.com/images?gbv=2&hl=en&sa=1&q=halo+armor&btnG=Search+Images&aq=0&oq=halo+ar
The first link has better pictures. Heres more links for reference pics.
http://photobucket.com/images/halo%20armor/
http://picasaweb.google.com/lh/view?q=halo%20armor&psc=G&filter=1#
THIS IS IMPORTANT
STEP 2: 2 Basics
Print the layout on card stock or heavy paper.
If you use heavy paper you might need to feed it into the printer one at a time.
BUY A BIG PACKAGE OF PAPER EACH PART OF ARMOR IS AT LEAST 7 PIECES OF PAPER .
STEP 3: 3 Hardest Step
After printing cut out all the pieces with scissors or a utility knife.
Fold and assemble all the parts. Use glue and small staples if you are sure they will be invisible when the armor is complete.
This is probably the step you are going to take the most time on.
This is the result of how your armor/weapons should look right now.
STEP 4: 4 Biggest Step
Get 2-3 buckets of aqua resin.
Apply one coat on the inside of the armor and give it at least an hour to dry.
Repeat with the outside.
You can carve out detail with a rotary tool they cost $15 at big art supply stores.
Now is the time to paint your armor. USE SPRAY PAINT The best color combination is
1. Primer
2.One coat of silver.
3.One coat of desired color. (Black works best)
Since your armor isnt very strong break up the fiberglass into small pieces. The pieces should not be any bigger than a.................. cracker or half the size of your cellphone screen (unless you have an iPhone, then go with 1/3)
Glue in the pieces of fiberglass ONLY ON THE INSIDE , REALLY .......... YOU WILL MESS IT UP TRYING TO PUT IT ON THE OUTSIDE.
After gluing in the fiberglass, put more glue on top and put in the foam (not Styrofoam) it should all ready be cut to size.
NOT ALL of the inside should be covered just in the center.
KEEP foam at least 1-2in away from the edge of your armor if you don't it will stick out and look ugly.
The foam should be about 1in thick.
1. Primer
STEP 5: 5 Helmet
After completing all the steps will notice that the helmet is not functional. To solve this problem cut out the visor. Carefully replace it with the motorcycle visor. You can find one on eBay or at a junk yard.
STEP 6: 5 Straping In
Now to make your armor wearable you need to find some log johns just like the ones it the picture.
Get black colored ones since they look like realistic under-armor.
HERES A VERY IMPORTANT TIP: GET LONG JOHNS THAT ARE 2 SIZES BIGGER THAN YOU SO YOU CAN WEAR YOUR ARMOR OVER CLOTHING.
You will need a friend to help you in this step.
Put on your long johns. Start with the chest piece and work your way down.
When putting on your armor be sure to strap it in tightly.
A good idea is to use plastic buckles (picture bellow) but only if you can hide them under the armor.
After putting on a piece of armor move around to be sure its comfortable.
This step may take a while, but if you don't take your tine you will regret it latter.
STEP 7: 6 Final Step
Make weapons the same way but without the foam.
contact me at:
coolgameweasel@aim.com or visit my myspace at myspace.com/weaselonferrari
HAPPY BUILDING
COMMENT PLEASE
contact me at:
HAPPY BUILDING
COMMENT PLEASE
40 Comments
cjfive5 9 years ago
laval909 8 years ago
agreeded
auhryn 10 years ago
How thick should the fiberglass be?
Thanks in advance
1. Doesn't matter
2. I recommend about half an inch but if the armor is to big for you probably all the way until it's comfortable and fits you
3. Np
slawrence2 12 years ago
yes
ghostrider2 12 years ago
Master-Chief 13 years ago
rjbthor 13 years ago
Email me at rjbthor@yahoo.com asap if you are willing.
yoshi1 13 years ago
yoshi1 13 years ago
weasel999 13 years ago
im not even posting any instructables even though i have ben doing quite a lot of projects
briackman 14 years ago
dont judje me by the lack of pictures
if you would be kind to give me a cammera 4 xmass i will flood you with pictures
pendalf 14 years ago
i didnt get the whole armor done yet (after 2 years) and i found bfx abot halfway through the build
darkscourge22 13 years ago
theres a free viewer
but the designer is pay
the viewer will work just fine unles you plan to desighn ur own project
soorry 4 spells
hhhttt 14 years ago
MerlinMakes 13 years ago
