Handyman's Valentine Gift - Screw-Nut Rings Pair - Home Made in 15 Mins
Intro: Handyman's Valentine Gift - Screw-Nut Rings Pair - Home Made in 15 Mins
Still not get a Valentine gift ready for your love? Here's one you can make in 15 mins. Actually it's one pair - for you and your loved one.
It's a pair rings of screw and nut. Perfect for DIYers, and perfect fits for lovers. The idea comes from A Perfect Fit. The original is from Kiley Granberg. The original rings are made from 24-karat gold, starting about $2,500!
Don't worry, if you don't have that much money like me, I've made an alternative costs only about 25 cents. And if you're handy enough, it won't take you more than 15 mins.
OK, let's get started. Valentine's Day is not far away.
STEP 1: What You Need?
Materials:
- 1 x Brass screw and nut, #6, available from hardware store.
- #14 copper wire, 6" long. I took a ground wire from the #14 cable.
Tools:
- solder iron and solder (avoid Pb, use lead-free solder. Thanks worldgnat)
- vice
- hacksaw
- steel wool, hammer, pliers
Tools:
- vice
- hacksaw
STEP 2: Make the Bands
- Bend the copper wire around a steel tube and cut to fit the fingers
- Hammer the ends a little bit. Polish with steel wools.
- Pre-dip with solder for easy assembly later.
You need one for you and another one for your couple.
STEP 3: Modify the Nut and Screw
With a hacksaw,
- Cut the screw to around 5mm long.
- Slot the nut half deep
With a triangle file,
- file V shape slots on both nut and screw head.
- Pre-dip the V slots.
STEP 4: Solder, and Done!
Have a look. They fit perfectly. So do you!
Happy Valentine's Day!
88 Comments
11richie21 9 years ago
its so you could screw your gf's nuts
dianaw 11 years ago
skullhead 11 years ago
yeah i know 14 years ago
imshanedulong 12 years ago
raja681 13 years ago
jdavis65 12 years ago
gibson_se 14 years ago
alterator 12 years ago
mikesnyd 13 years ago
AuzzieGuy42 13 years ago
Although I'm unsure how the soldering of the nut and bolt would go..
Weissensteinburg 15 years ago
kreationism 15 years ago
smurfsahoy 15 years ago
Switch and Lever 14 years ago
There are better metals to make jewelry from, the problem is really the combination of being both malleable and safe. Silver, if you use the right alloy, is pretty awesome at that though, and is not ridiculously expensive.
sugarsong 13 years ago
porcupinemamma 14 years ago
thepelton 15 years ago
arb1ter 13 years ago
