Hanger Lamp
Intro: Hanger Lamp
This instructable will show you how to create the 'Hanger Lamp' I have designed as part of my BA Product Design final project. My project is based on democratising Upcycling by making designs freely available for re-creation by anyone, I chose to do this as I had noticed that although Upcyled designs are made from free and abundant materials the prices being charged for such designs were pricing many out of the market and creating an exclusive style club for the rich. In order to prove my concept I will need other people, across the globe, to recreate this design and post it to me in London to be displayed at my degree show in June. Please visit my blog Design Democracy for more information, designs and news.
STEP 1: Tools & Materials
Materials:
1. Drinks can (500ml is best as it long and has a large diameter)
2. Wire coat hanger
3. Length of 2-core wire (2 metres is a good length)
4. Standard Plug
5. Pendant Bulb holder (the type used on ceiling lights)
6. Small energy efficient bulb
Tools:
1. Permanent marker
2. Scissors
3. Wet & Dry abrasive paper (320 grade)
4. 2mm drill bit
5. 30mm hole cutter
6. Hacksaw, Band saw or Stanley knife
7. Mole grips (Vice-grips)
8. Pliers
9. Can cutting template: download from here
2. Wire coat hanger
4. Standard Plug
Tools:
1. Permanent marker
2. Scissors
4. 2mm drill bit
5. 30mm hole cutter
8. Pliers
STEP 2: Print & Cut Template
Print the can template and cut around the bold outer lines.
STEP 3: Mark Can for Cutting
Take your template and affix it to the can, then draw around the edge of the template to mark the can. (I usually just wet the paper and dry off the areas of the can immediately surrounding the template, this saves glue and you don't have to wait for it to set!)
STEP 4: Drill the Bulb Holder Hole
Remove the template and drill a small hole in the centre of the can's base. For this you will need either a pillar drill or a friend that trusts you enough to hold the can whilst you drill. Once the small pilot hole is drilled it is safe to drill the larger hole to fit the bulb holder. Following the pilot hole use the hole cutter to SLOWLY cut the larger hole.
STEP 5: Cut Off the Top
Cut the top of the can off using a hacksaw, Stanley knife or, if you have one, band saw.
STEP 6: Cut the Can to Shape the Shade
Using the scissors, cut around the line marked earlier with the template. The corners can be tricky so avoid them in the first cut and remove the bulk first.
STEP 7: Clean Up Sharp Edges
Clean up the cut edges of the can using the Wet & Dry paper, you will get a better result if the paper is wet but not soggy. Ensure you remove any burrs (sharp, spiky bits), the best method is to sand parallel to the edge of the metal then lightly sand round each side of the edge at a 45 degree angle. Let the can dry fully before attempting step 11, unless you like to live dangerously of course, I prefer to keep water away from electricity as it really hurts when it goes wrong!
STEP 8: Bend the Hanger Into Shape
Bend the hanger into shape, for best results follow this order:
1. Bend the hook into a smaller circle around the bulb holder. This is easiest using the mole grips and pliers
2. Bend the base of the hanger in the middle to about 90 degrees, the end result will be less than 90 as it will spring back but this is desired
3. Bend the base of the hook (just below the twist) away from the apex of the bend made before
STEP 9: Attache Bulb Holder to Hanger
Remove the top of the bulb holder (domed part) and push the thread through the hanger's hook and replace the top. Form a loop in the wire behind the holder and press into the slot in the hanger beneath the twist. Attach the bulb, place the lamp on the table and adjust the bend below the twist until it stands on its own
STEP 10: Attach Shade
Remove the bulb, unscrew the bottom of the bulb holder (cone shaped part) and push the exposed thread through the hole in the base of the can, replace the bottom of the bulb holder and bulb.
STEP 11: Finished!
Now that you have completed your lamp, why not make another and send one to me, for the fantastic opportunity to have one of your own creations displayed alongside my original at two design shows in June. The first will be at my degree show at the Truman Brewery and the second at New Designers, both in central London! For details please visit my Design Democracy Blog.
Thanks for reading and enjoy creating, remixing and tweaking the hanger lamp!
18 Comments
xxlauraxx 8 years ago
I like this simplicity of this lamp. Nice work!
cbg3868 13 years ago
Tinseltoy 14 years ago
Gorfram 15 years ago
designplant 15 years ago
A picky little point from the "Hope You Don't Mind" Dept.-
Was re-reading this today (am seriously thinking about trying to making one), and happened to notice:
"step 7 - Clean Up...
...Let the can dry fully before attempting step 14."
But we're done in step 11. While this does ensure that the can will indeed be fully dry long before we ever get to step 14, I'm not sure that's quite what you'd intended. :)
Please, please do make one, It will help me out so much and you'll be able to say that something you have made has been displayed at a design show in London! Send me a message when you have finished or visit my blog (http://designplant.wordpress.com) and I'll get the postal address to you and sort out paying for your postage!
And while I'm getting ahead of myself -
- Would you want just the stand & shade, or all the electrical parts as well? I think you have to use adapters to get US electrics to work on UK circuits; but then, you might want to do that to emphasize the whole "globalness" of the project.
- And would you need/want me to ship the bulb? I might be able to pack it well enough to get there in one piece, but if UK and US bulbs are interchangeable (are they?), it might not be worth the bother.
You must be living right - I wouldn't drink Red Bull on a bet (well, not on a small bet, anyway :), but yesterday some un-civically-minded litterbug left an empty 500 ml can just where I would find it. :)
(Imitating yours as closely as possible will be good for my first attempt, but I'm also keeping an eye out for some very "American," or at least distinctly un-British, beverage can to use for the one I'd send to you. Budweiser, maybe? Or (shudder) Coors?
Crusty_07 15 years ago
fire_weasel 15 years ago
lemonie 15 years ago
rimar2000 15 years ago
bumpus 15 years ago
HotPinkBulb 15 years ago
