Hanging Concrete Lamp
Intro: Hanging Concrete Lamp
This is a semi failed but fun hanging concrete lamp. It was originally an attempt to slip cast concrete, which didn't work out so I ended up flicking and smoothing the concrete on. This gives it a rough interior and smooth sleek outer shell which is surprisingly strong but much thicker then the original slip cast that I wanted.
I am new to concrete but am loving it so if anyone has ever done any slip casting with concrete I would love some tips.
What you need:
Light fixture
ABS styrene 2.5mm
Tape
Hot glue
concrete
sand (fine grit)
knife
small piece of foam core
What you need:
Light fixture
ABS styrene 2.5mm
Tape
Hot glue
concrete
sand (fine grit)
knife
STEP 1: Cutting the Mold
Print the two lamp guide templates onto A3 paper, and cut them out.
Tape them down to your 2.5mm ABS styrene.
Cut around each piece. You should have 5 pieces.
STEP 2: Making the Mold
Tape the pieces together. I found this easiest by taping on the straight edges first and bending and sticking them to fit with the curved edge.
Because these pieces have just been blown up from a tiny test model and aren't from a CAD the top is not quite flush so I pushed it in to a small piece of foam core then hot glued around the top. This should create a flat top for the lamp.
Cut or drill a small hole in this foam core for the lamp's wire to thread through.
Cut a circle plug the same size as your light fixture out of the foam core and wedge into fixture
If your fixture has holes where the concrete can enter glue them up. Wire up the light fixture on the inside and pull to the top. (although I cast the entire fixture inside the concrete on second thoughts I should have only cast half of the fixture leaving the top of the fixture exposed to stop the build up of heat within the lamp and concrete.)
STEP 3: Casting
What DIDN'T work: Slip casts
First I attempted a 1:2 concrete to sand mix which was on the runny side. So that I could pour it in to my mold and rotate the mold around, coating the walls with concrete. Unfortunately the concrete only left a very very thin layer on some areas of the walls which would never hold up, I thought that I could just do three or four layers to build up the strength but just from touching my mold the walls moved enough to crack the concrete. Again any ideas on how to achieve this would be great I really want to see if I can get the concrete so thin it glows with the light.
What did work: Flinging and smoothing concrete.
With the slip cast lining the walls create a thicker concrete mix still 1:2 concrete to sand but less water than the slip mold.
With a trowel (piece of ABS) flicked the concrete on to the walls where it would stay nicely.
Using the same trowel(piece of ABS) smooth it out to the texture you are wanting for the interior.
Leave to dry for 24hrs +.
Carefully demold and hang.
22 Comments
Emilumag 5 years ago
perec3 7 years ago
Hi! Very nice lamp! I would like to try, but is it possible to download the template to print? Thanks!
cbehrendorff 10 years ago
dneishtadt 9 years ago
anjin12 9 years ago
What was the final weight?
hgriffin1 10 years ago
HamishDudley 10 years ago
poofrabbit 10 years ago
debraderek 10 years ago
KemikalzAreFun 10 years ago
Labyrinth 10 years ago
Search "translucent concrete" for information on the "standard" approaches. I suspect but have not seen that replacing sand with very small glass or polymer beads might give you the effect you're looking for.
Even maybe the bondo brand resin mixed so that it dries really fast, and adding it in the concrete before the resin starts to harden. Then putting your thin layer on quite quickly. But That may be kinda tricky though.. Haha just brainstorming all the thoughts that come in x)
That's a very good idea.
woulda never thought of that one.
I guess I'm not exactly sure what kinda fibers your talking about..?
digitalia 10 years ago
Windsrock 10 years ago
