Harvesting Electronic Parts
Intro: Harvesting Electronic Parts
Have you ever needed a part, but didn't have the money to buy it? After coming across this problem a million times, I discovered this cheap quick solution. Many people have electronics lying around that they don't use anymore, why not go green and recycle the parts in these?
You will need these tools:
-Soldering Iron
-Pliers
-Assorted screwdrivers (including the Mini ones)
-Soldering Iron
-Pliers
STEP 1: Scavenging
First, you need to go around your house, and find objects that require electrical energy, that you don't use anymore. There are more of these things lying around than most people think.
Here are some examples:
Unused
-Remotes
-Flashlights
-Toys
-Sewing Machines
-Computers
-Radios
Then, take them apart. you might need to break the outside of these, but try not to damage any of the electrical parts inside.
Unused
-Remotes
-Flashlights
-Toys
-Sewing Machines
-Computers
-Radios
STEP 2: Setting Up
Now that you have all your electrical parts that you would like harvest, you need to set up your work station. its very simple, this is what you need:
-Plenty of light
-A comfortable seat and table/desk
-Ventilation (Like a window)
-Container for the little pieces.
-Soldering Iron
I used a Muffin tin to Keep the little parts in place. it works great.
-Plenty of light
-Soldering Iron
STEP 3: Harvesting
Now your ready to begin. take your soldering iron, and press it into the solder holding down the desired part. Wait until the solder melts, then pull the part out with your other hand. Its that simple. You can use this to get resistors, LEDs, Capacitors, and pretty much anything held on with solder, even the breadboard.
*** Do not keep the Iron on the solder for a long time, because you can damage the part, the board, or your fingers.***
Now your probably thinking, wow this guy sucks, a 5 year old could have thought of that. well as you think this, look around you. chances are there is at least one thing within sight that you don't use anymore. Go ahead, its calling your name. Recycle. This is one of the many ways to do it that people overlook.
19 Comments
master-maker 8 years ago
i was wounding how to get the pieces off thanks
Sassah122 10 years ago
dcastor 11 years ago
Thanks!
NostalgicStone 13 years ago
Joblessalex 12 years ago
Graydant 12 years ago
There is a little know secret to discharging the elements though, Rain water.
jcaresheets 13 years ago
bart245 13 years ago
coolmike8789 14 years ago
Simpson_jr 14 years ago
A way to do it more quickly...
Use a small (old !) electric grill and place your PCB, THT-components downwards, just under the heating spirals. Wait for the grill to get hot and... hit the PCB gently wit a screwdriver while it gets hot.
It will take some time for the solder to melt, but once the first salvaged part drops, most other parts follow soon.
With SMD-components one has got to place the PCB with the components upwards. Try to move an insignificant component while the PCB heats up.
You probably have to wait a little longer once you can, but then it's pretty easy to harvest most components with a knive or piece of metal.
Some SMD components are glued to the PCB, they'll still stick when all solder is melted. Just hit it with a little more speed and force to get those loose. You won't break pins since the solder is already liquid.
Last but not least, One should not forget health issues when gathering recycled parts this way. Good ventilation is a definite must, it's best to do this outdoors. One should also not use an oven/grill that is still used for the preparation of food.
The technique takes some getting used to and some components... may get damaged, but most turn out fine. A second hand grill shouldn't have to cost much more as $10-15.
Patented 14 years ago
www.instructables.com/id/Recycle-old-PCB-components/
Phoenixmill 14 years ago
tmuggie 14 years ago
I mean really......are you really saving the landfill from over flowing??
All of the crust that you are left with (for example: all of the plastic enclosures, ect....what are you going to do with that??
....I have an IDEA....send it to a liberal bonehead and let them recycle it.
sageserver 14 years ago
trojanx 14 years ago
atombomb1945 14 years ago
Bongmaster 14 years ago
