Hat Rack Wall Mounted
Intro: Hat Rack Wall Mounted
I wanted to hang my hats on the wall of my bedroom, but the simple hooks deform them.
So, I decided to make specific "hooks" for my hats.
STEP 1: What You Need
To make this you need :
- Ruler and pencil
- Metal sheets (here aluminium 180x70x0.5 mm)
- Hand shears or a strong pair of scissors
- Power drill with a drill for metals
- Clamps
- Sandpaper
- Personel Protective Equipment (PPE)
STEP 2: Cut and Drill
I used sheets of aluminium which had this dimension : 180x70x0,5 (mm)
After draw on it I used a strong pair of scissors (I know a hand shears could be better), to cut it like in the sketch.
Then I make a hole with a power drill.
Next, I used a piece of sandpaper to soften the edge.
STEP 3: Shaped
To shaped the sheet of metal, I used a bottle with a smaller diameter than the one I wanted to obtain : Ø75mm for about Ø120mm.
Next I bent the part which will be used to hang the hat rack on the wall.
STEP 4: Do It Again
STEP 5: Hang Them
Enjoy your work !
4 Comments
seamster 9 years ago
This is great!
I love the simple idea--it's an invisible hat rack! And the clean look of the wall with your hats on it is terrific.
Functional decor!
2ID 9 years ago
Thanks a lot !
Humm just a question, do you see the animated GIFs on the two last pictures ? That doesn't work for me...
Nope, just a blank wall!
2ID 9 years ago
I don't understand why that doesn't work, I'll look at that. In the meantime I'll put standard pictures.
