Introduction: Automotive Headlight Projector Mod V1.2
Out Dated Mod:
The projector mods I did are out dated at this time. There are projectors with much better optics, brightness and throw distances. If you looking for a long use projector, with inexpensive bulbs, like I was when doing this mod, I would suggest getting an LED based projector. They provide superior brightness, rich colors, and most of all ridiculous long life spans over using a bulb based projector. Most of all there very inexpensive. Seriously Check out Amazon for LED Projectors. Just remember to find the Native Resolution, Brightness, Inputs and check the user reviews before making your purchase.
Considering what you can get NEW and at a reasonable price, modding is just not worth it.
Modding your projector on the cheap!
With the simple use of a 12V Automotive headlight and a power supply.
The OEM replacement bulb for my projector cost ~$300! More than what I paid for the projector it self. And my power supply that powered the original bulb was almost toast. Using this guide you can use an automotive head light bulb for about $15 dollars.
If you like this mod please Digg It!
Please note: This project has been added to please check out my Halogen WORK LIGHT Projector Mod
WARNING: This mod involves modification of a power supply, projector, and a high power bulb if you are not comfortable with moding on this level, DO NOT attempt this mod. The writer is not responsible for any injuries or damages resulting from these instructions.
Step 1: Gathering Parts and Supplies
Step 2: Finding a Bulb
This mod "should" work on all projectors that can fit a high power headlight bulb in the area that would normally hold the original projector lamp. Most all newer projectors use a lamp cartridge that houses both the bulb and the non conductive reflector. You would have to find a suitable bulb and insert it into the cartridge. Most automotive bulbs are of the size I used in the instructable. Remember you need A LOT of light output, so a wattage of 110+ at 12v is recommended. (Add the high and low wattage values).The nice thing about my projector, the MVP800 is that is has no cartridge. It uses a glass bulb shaped like a rod with a ball in the center. The reflectors and lens are all part of the projector. (The round reflector closes around the bulb witch has been removed from the projector in this picture)
Step 3: Extracting the Bulb!
Step 4: Wiring the Bulb
Heres a how to : http://www.techwarelabs.com/guides/misc_mod/psumod/
Step 5: Wiring Some More
Optional: You may also want to reset the bulbs timer. The one in this projector counts down from 2000 hours, but is not necessary to operate the projector.
Step 6: Lights, Projector, ACTION!
I chose this image to show how light and dark areas will show up with the projector mod. This image displays very well on screen, however is VERY hard to take with a digital camera.
If you like my projector mod please Digg it!
