Head Mouse With MPU6050 and Arduino Micro
Intro: Head Mouse With MPU6050 and Arduino Micro
Hi everyone, here it is my new project, a mouse controlled with the movement of the head!
I decided to make this project once I received my accelerometer/gyroscope MPU6050 from IC Station, and I wanted to do something useful with this.
Then I found out that a "Head Mouse" already exists, made by Martin Millmore with another accelerometer/gyroscope: https://www.instructables.com/id/Head-Mouse-Game-controller-or-disability-aid/
Well here it is my version, made with an Arduino Micro and a MPU6050.
Thanks to IC Station http://www.icstation.com/ for the accelerometer/gyroscope they sent me, allowing me to create this project!
STEP 1: Materials and Tools Needed
Materials needed:
- Arduino Micro;
- accelerometer/gyroscope MPU6050;
- a Compeed box (I found this comfortable as Martin Millmore said in his guide);
- an elastic band;
- micro USB cable to USB type B (like those used for Android smartphones);
- cables;
- a pcb board;
- glue, or better, Sugru.
Tools needed:
- a computer with the Arduino IDE installed;
- soldering station;
- mini drill.
STEP 2: Building
2) Make a hole with the dremel on the Compeed box so the micro USB cable can reach the Arduino Micro, and two straight holes for the elastic band.
3) glue the board to the box and add the elastic band.
STEP 3: Code
Connect the board to your computer and load first the "Test" code to the Arduino to test if everything work fine. You'll probably need to change some values (everything is written in the code's comments) since I had to add a constant, beacuse values from the gyroscope are not "zero" when I'm not moving.
Use the Serial Monitor to check if you need to fix the "zero" of the gyroscope.
Once you found the right values you can load the program deleting the "Serial.print" part, that is equivalent to the standard code.
If you want the click function after a delay of time since the pointer has been in a 10x10 pixel zone load the code "with_click" to Arduino Micro.
Here there are the codes:
- standard code with only movement: https://www.dropbox.com/s/hnrhdtsoqzi8azr/Mouse_Gyro_ENG.ino?dl=0
- code to test the output: https://www.dropbox.com/s/t2f63ichd4g93n1/Mouse_Gyro_TEST_ENG.ino?dl=0
- code with movement and click after 2 seconds: https://www.dropbox.com/s/vdsg8jo1toebt4d/Mouse_Gyro_with_click_ENG.ino?dl=0
To use them you'll need the MPU6050 and I2C libraries:
MPU 6050: http://arduinomeetslinux.com/download/MPU6050.zip
I2C: http://arduinomeetslinux.com/download/I2Cdev.zip
In this site I found the libraries and the code from which I developed the programs of my project: http://arduinomeetslinux.com/content.php?p=5
Link to Martin Millmore's project with the LSM9DS0 instead of the MPU6050: https://www.instructables.com/id/Head-Mouse-Game-controller-or-disability-aid/
44 Comments
magicbillo80 3 years ago
ErdemD5 5 years ago
kod'da kütüphaneleri indirmeme rağmen hatta veriyor.!!!!!!!!!!!!!
banjing 6 years ago
Hi, tried using this tutorial with my arduino pro micro and mpu6050, got the correct connections but unfortunately its not working, can you help me why please. Thanks.
syaifulhuda 5 years ago
ErdemD5 5 years ago
unzquadatr 5 years ago
I need the pdf of the code ...
nithildass 5 years ago
Mouse_Gyro_ENG:33: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.move(vx, vy);
Clen 5 years ago
You must use an Arduino with Mouse libraries compatibility, like Micro or Leonardo.
Clen 5 years ago
Hello, first of all, I must say thank you for helping me doing this project. But I'd like to improve your code, with your code you just only click once, so you can't open folders, in order to be able to open folders I suggest you to write 1 click and 1 press with a delay between them, so you don't click twice but it opens the folder too.
I'm adding an image with what I mean to change.
KrzysztofS10 6 years ago
I soldered the MPU6050 directly to the Arduino to save space (4cm of cables in all) and the "at rest" values for my module were -700 and 75.
Mounted it into my DIY headlamp (left ear has a LED brightness knob, maybe I'll put mouse sensitivity over the right?
JakabF 6 years ago
Here's that project:
https://www.instructables.com/id/Build-Your-Own-Vacuum-Robot/
Gabry295 6 years ago
Your project is really interesting, the robot looks really good!
I'll take a better look when I have more time, I'm interesting in the algorithm that control the track of the robot
JakabF 6 years ago
My robot looks not even close to CesNieto's orignal build, as you can see on this video I made prior to the accelerometer upgrade:
https://www.youtube.com/watch?v=cPbY-wy9AqA&feature=youtu.be
ICStation13 6 years ago
Thanks for your awesome project. Great~~
Ayudas ParaT 6 years ago
great work,congratulations
YoyOA2 7 years ago
can this be done with a arduino mega ?
Gabry295 7 years ago
No, you need an Arduino Micro or Leonardo, which have the "ATmega32u4" that interfaces directly with the PC and can be recognized as mouse or keyboard. See more by Googling "Arduino Leonardo" and "Arduino Micro" and check the description on the Arduino official sites.
YoyOA2 6 years ago
ok.
i could implement other tasks, such as sustained click or secondary click, this with respect to programming?
PhilL76 6 years ago
I made a version which runs on every Arduino model using serial communication and python, but apparently I can't post the link here D:
ph77894456 7 years ago
