Headboard Repurposed Into a Coat Rack
Intro: Headboard Repurposed Into a Coat Rack
Turning a headboard into a bench is one of the most popular ways to repurpose an old headboard. I had this one sitting in my shed for years and when a friend asked if I could make her a hat rack I thought this one would be perfect.
STEP 1: Find an Old Headboard
This headboard was not very heavy because the panels in the centre were a thin plywood and the legs would be removed. I was going to cut them off but I found that they were already loose so a few taps with a hammer and the legs popped off.
STEP 2: Sand the Middle Panels
Because I needed to sand the inside panels to get rid of all the old varnish I found it was easier to take the whole headboard apart. It was all just slotted together so It would be easy enough to put back together.
STEP 3: Distress Wood to Hide Damage
I sanded down all the wood and notice that it had quite a few dents in the wood, to hide the dents I distress the wood further to blend in the dents. It was at this stage I thought the headboard might still be a bit big.
STEP 4: Shorten Headboard
Because it was all ready apart it was easy to cut about 10cm of each of the panels as well as the frame.
STEP 5: Prime Ready for Painting
I had planed all along to make the middle panels chalkboards that you could write messages on. Once they were all sanded down I added a coat a white primer and left it to dry. I used chalkboard spray paint and added 2 coats as per instructions on the can.
STEP 6: Protect Wood From Overspray
The wood was stain a dark mahogany and given 2 coats of clear polyurethane. I glued the headboard back together and used ratchet straps to hold it all tight while the glue dried. I wanted to add a bit of detail to the wood. I covered all the boards to protect them from any overspray.
STEP 7: Stencil Detail
I used a stencil and some copper spray paint to add a design to the top. This took a while because it was a single stencil and I had to wait for the one to dry before I started the next.
STEP 8: Add Hooks and Name Tags
I added some hat and coat hooks to the board and some copper name tag holders for added decoration. And cut a small piece of wood to add to the middle for the chalk to rest on.
STEP 9: Rack Complete
And that was my repurpose complete. A more detailed step by step is available on my website http://uniquecreationsbyanita.com/old-headboard-repurposed-into-a-chalkboard-hat-coat-rack/ another project you might like How to make a Chaise Lounge from recycled materials
Materials needed for this project
- Jigsaw or table saw
- white primer paint
- chalkboard spray paint
- paint roller
- coat and hat hooks
- stencil
- copper spray paint
- mahogany stain
- satin clear polyurethane
- orbital sander
3 Comments
SusanS337 5 years ago
I am curious what size the headboard is (dimensions or twin, double)? Also, I am wondering what your experience is with the chalkboard paint using spray on vs. paint on (is one better than the other; easier to use)? Thanks and great repurpose!
Kink Jarfold 5 years ago
This, Anita, is one of my favorite things you've done. You people from Down Under are really on the ball! KJ
AnitaH25 5 years ago
