Introduction: Headphone Hanger
make a headphone hanger for your computer table
Step 1: Things You'll Need
1.Self adhesive hook
2.Rubber bands 3-4
3.Binder clip
3.Some kind of foam (any type to add cushion i used a piece of foam tube)
4.A headphone?(very important)
did you notice double "3". it doesn't mean you are not brilliant. don't worry go on to next step
2.Rubber bands 3-4
3.Binder clip
Step 2: Stick Your Self Adhesive Hook to Your Table
stick your self adhesive hook to your table/wall/anywhere you want just make sure it'll stick with the surface Strong enough to hold your headphone's weight
Step 3: Binder Clip Step
take a binder clip and tie the two heads with rubber band so that it won't separate
Step 4: Tie the Foam
Tie the foam to one head of the binder clip using rubber band
Step 5: Hang the Clip
hang the binder clip like shown in this picture(this pic was taken before i tie the foam to the binder clip). now you are almost ready
Step 6: Your Headphone Hanger Is Ready
hang your headphone between the binder clip heads. before doing it make sure your adhesive hook is strongly stuck on the surface else your headphone will fall off very soon. if needed wait for an hour or two.
Step 7: Bonus Step
the binder clip will shake a little bit when putting a headphone on it. but it doesn't affect your hanger performance. in case if you want it not to move you can stick a double side tape to one side of the binder clip so that it'll also stick to the table/wall/etc
Happy Headphone Hanger DIY Enjoy show your skills post yours in comments
