Headphone Stand
Intro: Headphone Stand
After destroying yet another expensive gaming headset, by rolling over the wires with the computer chair, I thought it was time to make a stand for the new ones.
STEP 1: Materials Needed
I found a template that I liked and printed it out in Microsoft office. I traced the outline onto my wood. I used scrap wood I had from an old project. I cut 2 pieces so that my stand would be chunky.
Wood
Hole saw cutter
Sanding wheel
Jig saw
Sander
Glue
Varnish and Stain
Router
STEP 2: Cutting Out Your Shape
My wood was quite thick and I am not very accurate cutting out with a jigsaw, so I cut them about 2mm wider than the template. I glued the two pieces together and used my belt and disc sander to sand the two pieces to look like one, using the outline as a sanding guide.
STEP 3: Cutting Out the Hole
I marked out the center and added a hole to make it look better using a hole saw. I only drilled half way then turned my project over and completed the hole from the other side to prevent blowing out and damaging my project.
STEP 4: Sanding the Hole
I cleaned up the inside using a sanding wheel until the inside was smooth.
STEP 5: Router the Edges
And used a router to remove all the edges to give it a nicer look. And finally I sanded my project smooth and stain with dark Mahogany stain and gave it 3 coats of gloss varnish. Time for total project was 3 hours excluding drying times.
3 Comments
SanFranciscoWoodworker 5 years ago
If no template is available, could you tell me the dimensions and proportions you used ?
Marniacal 6 years ago
This is both functional and beautiful!
AnitaH25 6 years ago
