Heat Sink for Diodes
Intro: Heat Sink for Diodes
Where ever i want to reduce voltage i use rectifier diodes (1N4007), but the problems is that they get too much hot on passing too many ampere through them which may damage them. The only solution i found was to create heat sink to keep them cool.
I used 2 series pair of 2 diodes, connected parallel and attached my heat sink on them. Believe me or not my diodes worked fine even on passing 12 volts and 15 amperes through them.
STEP 1: Things You Will Need
1. thick Aluminum foil
2. diodes
3. toothpaste [conductor paste (if possible)]
4. stainless steel wire
5. pin
6. scissors/cutter
7. waterproof box
STEP 2: Cut Out Long Stripes of Aluminum Foil
STEP 3: Smother the Stripes by Rubbing Any Hard Thing on Them (e.g Blade)
STEP 4: Wrap the Aluminum Stripes Around the Diode (as Shown in the Picture), But Then Pull Out or Unwrap the Foil in Such a Way That the Shape of the Diode Stays on Them
STEP 5: Add Toothpaste or Conductor Paste(if Available) on the Aluminum Stripes and Then Place the Diode Back in the Aluminium Strip
STEP 6: Make a Hole in the Aluminium Stripe From a Pin and Then Tightly Clamp the Stripe Around Diode From a Steel Wire.
STEP 7: Congratulation ! You Have Made a Diode Heat Sink.
Now it depends upon you whether to dip the heat sink in water or you place it in a ventilated box.
9 Comments
tomatoskins 8 years ago
Cool idea for making your own heat sink!
Harris Naveed 8 years ago
thanx!
dionisiodar58 4 years ago
elpayo 6 years ago
genius!!!
Salman Naveed 8 years ago
You literally sink the diodes in water so that they lose heat. Hilarious and creatively imaginative at the same time! Well done!
I can understand your jealousy bro, cause i know you instructables have never been featured once.
I would recommend you to better wash off you face before commenting because i have only dipped the aluminium fins in water. And if you still don't understand then you must take a whole bath.
Dabluebunny 7 years ago
Yonatan24 8 years ago
Just use cheap Thermal Paste, It's really cheap on eBay
mrcreosoate 8 years ago
Have you thought of measuring the diodes diameter and heat shrinking the wires ,then drill any metal block you can get your hands on Then thread them through the hole ,maybe with some heat sink compound ?
