Introduction: Heavy Duty Paracord Dog Leash
About: I am a paracord fanatic who has mastered the art. I am a good shot. Love Marvel and DC comics. I'm a Boy Scout. Can survive and thrive in the wild. And I can cook.
A good dog leash is hard to find, making you're own with 550 paracord ensures that it will last a lifetime. If you read my previous instructable "glow in the dark paracord collar" than this will go perfect and complete a set.
*note* to do this leash you must have a basic knowledge of the cobra knot used in paracord.
Step 1: Materials You Will Need
1. Scissors
2. Lighter
3. Measuring tape
4. A Dog (must be real or it will be weird)
5. Two 20 ft length of two different colors fused to make one length of 40 feet.
6. 10 ft of paracord separate from the rest (this will be your base)
7. A cat that gets into everything (you will understand when you see the photos)
8. A metal clip (this can be reused from an old dog leash)
Step 2: Attaching Paracord to the Clip
After you measure and cut your paracord. Take the 10 ft cord from the middle and slip it through the hole. Pull the loop over the clasp. Now take the the other end of the paracord and pull the two ends of the cord through the loop and tighten.
Step 3: Starting the Knot
To start the knot tie a simple cobra knot, instead of looping the cord on alternating sides, keep the knot going on the same side ( this will cause the paracord to look like a typical cobra knot, but to spiral I na helix). If your confused just look at the pictures. See photo number six is what it should start to look like.
Step 4: Keep Tying
Keep trying in this fashion until you have reached the desired length of the leash. Make sure to leave enough cordage in order to finish the handle or loop at the end. Proceed to the next step to learn the process on how to create the loop handle.
Step 5: Starting the Handle
Take the end of the the ten ft long base and place it in a loop in order to weave over it. Give yourself at least 8 inches of overlapping in order to strengthen the loop. Right now you should be weaving over four strings. Keep weaving until the loop is big enough to fit your wrist in comfortably. When you have reached the size that you feel comfortable with, separate the four strands into two strands and weave with a standard cobra weave so it's flat. Continue until the loop is completely covered with the cobra styled weave. Now take the crotchet hook and pull them through the last knot on the leash.
Step 6: Go for a Walk
Now that you have a new leash, and if you followed my previous Instructable, a new collar take your best friend for a walk.
