Introduction: Heckler & Koch HK416 Instructions
About: Get off your computer and out into the real world. Bit hypocritical since i spend a lot of time on wikia........but anyway. I'm Knexpete, also known as Heatedpete or Heat. I spend a lot of time tweaking my cur…
 these are the instructions for the HK416 that i made a week ago
the pics are taken by a cruddy VGA camera, so plz dont complain about picture quality
the hk416 is a version of the AR-15 (this later becomes the M16) that's been completely redesigned for increased accuracy and reliability. my gun.....doesn't fire, but looks aesthetically the same, but with a few design errors:
1) the stock is fixed in place, when the real one can be extended/retracted
2) there are no side rails on the barrel
3) the grenade launcher is an M203, not the real one the HK uses
Step 1: Body of Gun
 this step will make the body of the gun
see the picture notes for explanations
Step 2: Barrel
 This barrel came from Barrax's Updated Remington ACR (www.instructables.com/id/Remington-ACR-Adaptive-Combat-Rifle-Knex/) i added the grey connectors on the bottom so that i could fit my grenade launcher/Masterkey shotgun, and also modded the top so i could fit the top rails
Step 3: Magazine
 this is The Dunkis' STANAG magazine, but it will not hold any bullets/rods. Good instructions for a magazine that can hold rods are on Dutchwarlord's TAR-21 instructable.
Step 4: Stock
 this step is rather simple, but is very important, so don't muck it up!
As the largest empty space in the gun, it is the best area to fit a firing mechanism
make sure u have the second body panel ready, for you'll need it in the next step
Step 5: Assembling the Gun
 this is by far the hardest part of the gun
do not put the final body panel onto the gun until the stock and barrel have been attached
remember to add the rubber bands in the final picture
TIP: when attaching the final body panel, detach the pieces that have to be attached to the blue rods and attach them to the rods, then attach the rest of the panel as that's easier to do
Step 6: Top Rail and Accesories
 this step will allow you to attach sights and grenade launchers to the gun
follow the in-picture steps and you should be fine
Step 7: Finito!
 now, ur done!!!!!!
if you can, plz find a way to create a firing mech for this gun, as i want to make it shoot good!
have fun with this HK416, then comment, rate and subscribe to me!
