Helping Hands
Intro: Helping Hands
Ive seen a lot of helping hands on here and decided to make a version of my own because i really needed one.
STEP 1: Materials
Parts:
coax cable
alligator clips
screws
piece of wood
heatshrink tubing
spade terminals
Tools:
drill
lighter
x-acto knife
wire crimpers/ wire cutters
screwdriver (phillips)
STEP 2: Make the Arms
Cut the coax cable to the desired length. Then I used an x-acto knife to cut down the cable and took off the outer layer and a coating of wire under the outer layer. then slide one end of the cable into the alligator clip and crimp it. i put a piece of heat shrink tubing over it too. then put the other end of the cable into the spade terminal and crimp it again. Do this for as many arms as you want. i made 3 with alligator clips and one with a magnifying glass.
STEP 3: The Base
Drill holes in the wood for the screws. when you get the screws screwed in, slide the spade terminals on the cables under the screws and tighten them to hold the arms in place. I figured this would be easy to move the arms or switch them around.
STEP 4: All Done!
There are endless possibilites to what you can make for legs and attatchments. Please rate and comment. I hope you enjoyed this instructable. Thanks for viewing :)
7 Comments
OzzyManson 11 years ago
putty1cat 13 years ago
musick_08 13 years ago
Computothought 14 years ago
http://computoman.wordpress.com/2009/09/24/geek-project-of-the-week/
musick_08 14 years ago
RadBear 14 years ago
