High Power Flash.
Intro: High Power Flash.
An ongoing project for creating a high power and speed studio flash (cheaply) that can sync with a chdk enabled camera.
Once I get the new parts (couple weeks ish) I'll make an instructable.
If you don't know what chdk is have a look:
https://www.instructables.com/id/Pocket-Sized-CHDK-USB-Camera-Shutter-Remote/
Currently I can take photos at about 1/1000s consistently.
I believe the limitation is the camera.
As the flash timing moves about +-1/4ms
The bulb is being run at about 7.5j, but is capable of about 32j, so I'm going to get a proper sized tank capacitor and use a voltage doubler off the line to charge it faster.
6 Comments
gaveno 10 years ago
Photomancer 11 years ago
The problem is the "flash" can be on for much shorter periods, say 1/50,000th of second. I'd suggest, get everything set-up, turn the lights off or very dim (I mean barely able to see) the set the camera on B (Bulb) - shutter stays open. Have you device trip the flash to coincide with the event, say balloon popping. Then close the shutter, and now the exposure is limited to the actual flash duration.
The more clever part will be to have the device with start button that turns off lights about 1 second before "pop" the balloon, the trip shutter, say set for 1 second exposure, then immediately do the "pop", shutter closes after 1 second, then lights come back on a second later. It'll take some tests to get the exposure right for a given distance. But once dialed in, should be good for any item.
Good cameras can go between 1/250th (my Nikon) to 1/500 (Mamiya, different type of shutter) of second with their flash. You've already topped that, but almost all high speed photos are done in the dark with the flash controlling exposure time.
Just some thoughts: Maybe the pin that trips the flash when it touches something and grounds so the circuit is almost instantaneous. A sonic pick-up that is 12'' away will have about 1/1000th of second delay just do to the speed of sound getting there. A laser maybe?
I know much more about cameras a flash photography than electronics, just starting out Ardunio projects. Good work you've given me some ideas. Looking forward to your expanded instructable.
VadimS 11 years ago
etw 12 years ago
CieNTi 12 years ago
