Introduction: How to Make a Router Sled to Flatten Slabs
Hi! I'm Matt. Follow along as I make a router sled/slab flattening mill. This is a great way to flatten work pieces that are too large to fit in a standard planer, drum sander or benchtop CNC. With just 1/2 sheet of plywood and my router, I was able to surface and flatten a massive 20x24x3" end grain butcher block!
This is really a simple build. A half-sheet of 3/4″ ply and your plunge router is about all you really need to make this router sled/slab flattening mill. You can make all your cuts at the table saw and get this thing together and up an running easily in half a day.
• Make sure to watch my accompanying YouTube video of this build!
• If you would like downloadable plans for this build: DOWNLOAD PLANS HERE
Where to Follow along with my work:
My Website:mwawoodworks.com
Youtube:youtube.com/mwawoodworks
Instagram:instagram.com/mwawoodworks
Pinterest:pinterest.com/mwawoodworks
Here are the tools I used specifically on this build (affiliate links):
Collet Extension (for better reach)
150 lb Mag Switch (6 is ideal)
1.25" Mortising bit this is the economical option
Amana Surfacing bit this is the much better (and more expensive) option
Step 1: Cut the Rail Parts
I cut six total 48″ strips (2) 4″ strips for the base of the rails, (2) 3 3/4″ outer rail parts and (2) 2 1/2″ inner rail parts. The heights for the rails are up to you based on how much capacity you want under your sled. Just make sure the inner rails a 1 1/4″ thinner than the outer rails. A 12″ scraps of 3/4″ ply is all you need to cut (4) 1 1/4″ rail guides.
Step 2: Build the Rails
Carefully clamp one inner and one outer rail together, ensuring that the bottom edges line up perfectly. Pre-drill and countersink six holes along the inner rail. I used THIS router bit from Amana Tools to get this done. Fasten the inner and outer rails with 1 1/4″ screws. I would not recommend glue for these rails. The water in the glue may cause warping in such thin strips of plywood. Cut a 1/8″ deep dado the width of your rails (1 1/2″) centered on the rail bottoms. This is to allow the rails to sit inside the dado and helps to ensure the rails stay straight. Fasten the rail bottom to the rail with screws (pre-drilled and countersunk). Now the rails are done! I would advise breaking the edges of the rails with a block plane which will make the sled ride more smoothly along the rails.
Step 3: Cutting the Sled Parts
To cut the bottom of the sled, use your router’s base to set the width of the cut. Add 1/32″ to this measurement to allow just enough room to prevent binding when the router moves across the sled.
Next, cut out the sled sides. I made mine 3″ high. At the drill press, drill two 1 1/2″ holes at either end of the sled bottom. This will serve as the beginning and end of the slot.
Use feather boards to keep constant downward and lateral pressure against the work piece.With the saw blade retracted, slide the work piece over the blade.
Turn on your saw and slowly raise the blade up through the plywood. ** PLEASE USE CAUTION** always be aware of where your hands are with regard to the blade since you are blindly raising the blade through the work piece.
Now run the piece across the blade until you reach the holes on either end. Repeat this for the other side. Make sure when you cut the other side that you secure the waste piece in the middle with your fingers so that it doesn’t wander into the blade and cause kickback. Once again, exercise caution with your hands and keep them well away from the blade.
With that done the bottom is complete. Now just cut the sides for the sled with a miter saw. I made mine 3″ high.
Step 4: BuildThe Sled
Clamp and screw the two long sides of the sled to the bottom. Make sure to pre-dril first. Now fasten the ends to the base with screws. Next, use cyanoacrylate (C.A. glue) to hold the first rail guide to the edge of the base. The CA glue is meant to hold the rail guides in place until they can be fastened with screws. Now add a scrap piece of 3/4″ ply as a spacer and again glue the second rail to the sled snugly against the scrap piece. Once the second rail is in place, move the spacer to the top to avoid it being glued in place. Attach the runners using screws. I broke the edges of the rail guides with my block plane to create less friction and make things slide better.
Step 5: Complete the Assembly of the Sled
Now set the sled on the rails to get the spacing set correctly. Clamp the two rails to your work surface. Then slide the sled to the other side, making your rails parallel to one another. I used my table saw because its the flattest work surface in my shop. Because I couldn’t clamp the other end of my rails I had to screw them to the bench. Use furniture polish to lube up the inside of the sled where the router will sit.
Step 6: Lubricate the Rails
It turns out using paste wax is a bad idea. Instead, use dry lube. It wont attract the sawdust and gunk up the rails causing binding. Just spray it on and it dries in seconds. Now everything should be nice and slidy slidy!
Step 7: Operating the Sled
I used a 1 1/4″ mortising bit, but I could have used a surfacing bit just as easily. Anything with a wide flat cutting edge. I also used a collet extension. This tool gives you the ability to extend all the way down to the workpiece. Now with the router OFF, find the lowest point on the surface of the material. Just plunge down until the bit makes contact. This is the depth you will cut to. To hold my workpiece in place, I used 150 lb mag switches to keep the work piece from moving laterally. Since the work piece weighs over 40 lbs, there’s no need to fasten it down, it will stay in place. I also used a shim here to remove any rocking. Make sure your router bit is away from the surface of the workpiece and turn the router on. Now slowly move onto the surface of the workpiece and make your first cut by slowly passing the router over the surface, adjusting it about 3/4″ on each pass. Once you surface one side, flip your work over and repeat the process. Note, I didnt need the shim anymore because this side was now flat. Once you’re done, remove the router and the sled and sweep off your work. After a 60 grit sanding with the Rotex first to remove the mill marks and then progress in grit to 220 with a random orbit sander and you get a smooth flat finish.
Step 8: DOWNLOADABLE PLANS!
If you'd like added help with this build, I have downloadable plans you can purchase!
In this 5 page PDF plan:
1. Essential materials list
2. Cut diagrams
3. 3D diagrams with detailed steps to build the project
Note: Measurements are in imperial
Step 9: THANK YOU FOR FOLLOWING ALONG!
If you enjoyed this tutorial and found it helpful, you can see more of my work in the following places:
My Website (full tutorials, plans, videos): https://www.mwawoodworks.com
My YouTube (all my build videos): https://www.youtube.com/c/mwawoodworks
My Instagram (behind the scenes stuff): https://www.instagram.com/mwawoodworks
My Pinterest (things I find inspirational) : https://www.pinterest.com/mwawoodworks
13 Comments
1 year ago
"Pre-drilling?" What would that be? Something you do before you drill?
One drills "Pilot Holes" to 1) prevent splitting the material "screwed" and (as the term suggests to Inner Harbor Seamen perhaps) 2) guide the screws. Counter sinking is often done as part of the process of drilling Pilot Holes to accept screws while allowing the screw heads to be positioned below the surface of the exposed material.
3 years ago on Step 7
Excelente trabajo! No perdiste detalle!!!
3 years ago on Step 1
Hi there. Thanks for this tutorial and your Youtube videos. I really like your fence and was wondering if you had a plan for it.
Reply 3 years ago
Thanks for the kind words! No plans for the fence yet, but I've had a lot of encouragement to make some, so stay tuned..... :-)
3 years ago on Step 9
Love it and really nice toutorial. I had to make a knife switch style router device for this piece that was the same kind of idea but for curves.
Reply 3 years ago
Man I have seen a couple sick ideas for this and I would love to tackle 3D shapes with the router one day!
Reply 3 years ago
Bit of advice on that. Keep your hinge mechanisms tight as hell. Vibration is the killer. My final build used a massively strong spring to hold down the piece as I rotated it and I had to hammer in the bolts that I used to make the knife switch. Zero play in any aspect of the device. My first attempt was a tiny bit loose and it made dog food out of it.
3 years ago
Very nice.
Will use it.
Think it is inappropriate to offer your plans for sale through this platform.
Reply 3 years ago
I'm so glad you find my work useful! It means a lot cause I put a lot of time and work into filming and editing my videos and writing thorough blog posts. As for plan sales, I felt like it was better than having no plans at all! Thanks again, my friend.
3 years ago
Nice job, Matt. I may just have to make this to increase my tiny workshop's capabilities!
Reply 3 years ago
For the amount of materials needed you can't do much better. It's so handy for this specific problem.
3 years ago
Great looking sled! I made one a while ago but with metal rails, and whatever else I had in the shop at the time. It's a great thing to add to the tool arsenal! Your design looks good!
Reply 3 years ago
Yes metal rails are a great upgrade! This was just my solution given only half a sheet of ply and it works great especially with the aid of my flat table saw surface to reference off of!
