Hollow Bed Post Gun Storage
Intro: Hollow Bed Post Gun Storage
If you kick in my door in the middle of the night, you better be ready to deal with the consequences.
STEP 1: Remove the Post Cap.
My bedpost on my bed frame is rather wide. Perfect for stashing burglar deterrents.
I started by putting a block of scrap wood under the lip of the post cap and tapping it loose with a hammer.
It was secured with glue and 4 dowels (one on each side)
As soon as I had enough clearance I sawed through the dowels with a fine tooth razor saw.
STEP 2: Modify the Post
The hole down the center of the post is deep. So to bring the bottom up to a level where I can easily grab my gear, I built a leg.
I measured the distance to the bottom of the post and subtracted the distance I wanted the shelf to be from the top.
It is simply a piece of scrap 2x4 from my garage with a piece of square plywood attached with one screw. I cut the plywood square about 1/8" less than the opening to make an easy fit.
Once assembled the leg just drops in.
I chiseled out notches in the post and the cap so I could mount a small hinge and still have the cap sit flush.
Then using a fortsner bit I drilled holes to allow rare-earth magnets to be flush mounted. I initially glued them in, but that didn't hold. So at the bottom of each magnet hole, I drove a bugle head (flat top) screw in. I then use expanding polyurethane glue (Gorilla) and set the magnets in. Then I had to chisel a grove to mount the flat metal bar on the cap. I think it may have been overkill, but I mounted 2 magnets behind the bar as well.
It works great. You really have to pull hard to open it.
STEP 3: Load Up Your Gear
My security blanket...
I live in a nice neighborhood. I have polite, nice, quiet neighbors.
But I also have a wife and two kids who know that I'll do anything to keep them from harm.
17 Comments
nsxtech 8 years ago
I LIKE it! My bed has 4x4 solid corner posts, so that's a no go for me. :-(
Just living in a nice neighborhood is not enough unfortunately. Bad people go to nice neighborhoods to do their deeds because that's where the nice stuff is found.
Thanks for sharing!
Eye Poker 10 years ago
Picasso88 8 years ago
that would be one heck of a deal!!
LokiWartooth 8 years ago
tate219 10 years ago
agoodguy 10 years ago
kyle brinkerhoff 10 years ago
well done. what would be a good idea is to add just a dab of glue to the edge of the box, not enough to glue it shut but if by some chance a kid where to get curius and try to open it they wouldnt be able to apply enough force to get it open were as an adult could easliy lift the lid forcing the glue to break. this would complete the illusion of a completely inocuos bed post. but im not responsible if you end up using too much glue that you cant pry it open again....
darth_101 10 years ago
I would put in a heavy duty latch opened wit a hidden wire to store other valubles.
NaNaNaNaBatman88 10 years ago
finton 10 years ago
Great idea and well executed - um, I mean made...
LJ2MAKE 10 years ago
riffblazer 10 years ago
TeeDum 10 years ago
astral_mage 10 years ago
jweinstein jr 10 years ago
PACW 10 years ago
