Home Made PC Water Cooling
Intro: Home Made PC Water Cooling
One of the most enjoyable things to do in your spare time is to make gadgets and mods to your computer. This DIY project shows how you can add an efficient water cooling system to your computer using affordable stuff and with lots of fun.
STEP 1: Tools
You will need the following:
1.A drill.
2.A normal CPU heat sink.
3.A copper tube. (like the one used in refrigerators)
4.A plastic tube.
5.An aquarium pump.
6.A glass or plastic Jar.
7.Distilled water.
8.Epoxy - Plasticsteel
1.A drill.
4.A plastic tube.
5.An aquarium pump.
7.Distilled water.
STEP 2: Preparing the Water Block
The water block is designed to cool the CPU. The block which water runs through is made out of a normal heatsink which is normally attached to a fan that comes with the CPU.
The process of preparing the water block begins with deattaching the fan from the heatsink and then making two holes in the middle of it. The holes end must reach each other to allow water to pass through and that was achieved by drilling holes in diagonal drilling procedures
STEP 3: Preparing the Water Tank.
Use a normal glass or plastic jar and fill it with distilled water to be your coolant tank. Insert the aquarium water pump in that jar after attaching a plastic tube to it to allow water to run and reach the water block. Make three holes in the jars cover one for the outgoing water tube and another for the incoming water tube and the third for the pumps electricity wire.
STEP 4: Preparing the Radiator
An efficient radiator can be made using a copper tube allowing the water to be cooled by going in circles. You can add a normal fan to get air through the circles of the tube which will provide a better air flow and cooling.
STEP 5: Bring Everything Together
After finalizing your radiator, attaching everything together is easy. By attaching the heat sink (water block) to its original place and positioning the glass jar (coolant tank ) in the PC case in my case I choose to put it under the HDD.- and you should also weir the pump with your power supply, you can use a relay to start the pump when the PC initialize.
STEP 6: Final Project
As you can see you can make your own water cooling system from almost nothing and using none of the original tools used in preparing a water cooling system.
The block is an original heatsink from an original Intel fan.
The tubes used are the ones you can find in a hospital or pharmacy.
The water pump is an aquarium water pump.
This project is easy yet efficient as the temperature after installing the system reached only 24c.
This project was made by Waseem Abusalem and Essra Hourani.
95 Comments
shrishsingh888 3 years ago
AndreasH17 7 years ago
Wich CPU do you have? And what are the Temps under load? I'm sure not soooo great, i have milled myself an cpu block made out of cooper with much much more surface and have still 55°C on it. (Core i5 6600k @4,7 ghz 1,34V)
elmoutakafE 8 years ago
http://dztubes.com/ me
http://dztubes.com/
silentx 8 years ago
This is a horribly bad idea.!!!
Copper+Aluminium+heat+PC=DEAD PC and Wet Floor!!!!!!!!!!
Copper is a strong corrosive for Aluminium!! Copper ions will leach in water and It will eat away at the aluminum and eventually water will leak out. Heat will accelerate the process. You can add additives to delay the corrosion but you will only delay the inevitable. The process is called electrolysis.
Never combine Aluminium with copper or its alloys (brass)
Techmov 9 years ago
twitsl 11 years ago
ianmcmill 12 years ago
does this heat sink have a solid core ? your are just drilling in two holes that connect inside the core to let the water flow ?
helios5993 11 years ago
Sky Graham 11 years ago
Anti-freeze has a lower boiling point than water under pressure.
If the pressure is removed both will boil very rapidly.
So if your vehicle has a vacuum leak, and air gets into the system, both the water and antifreeze will boil rapidly, the radiator fan wont be able to cool it down, and then your engine will overheat and explode/die.
This is not a radiator under high pressure with high temperature water, so the anti-freeze is not going to help in that respect.
Anti-freeze is poisonous, it also smells sweet and tastes like sugar, one or two tablespoons will kill your dog/turtle.
If you want it to look cool, toss a highlighter into the blender with water and use a black light.
glacier24 12 years ago
air pump or water pump?
and hot do i drill the heatsink??
Graffstar 12 years ago
Minifig666 13 years ago
kedwa30 12 years ago
knex hitman gill 13 years ago
B.F.L.M 13 years ago
rahimosahra 13 years ago
