Home Made Solar Power System
Intro: Home Made Solar Power System
I really wanted to try out solar power. I decided to make this. Ive put the whole thing in my lockers in my room.
STEP 1: Parts
Parts:
2x 5watt mono-crystalline solar panels
1x 12/24 volt, 10amp solar charge controller
Any gauge wire, length depends on what you need.
Batteries: i have 2x 4.5amp at 12 volts and one 8amp at 12 volts.
Inverter(for powering other things)( i think mine is 140watt continuous and 250 watt peak)
12 volt cigarette lighter sockets
Lights or what you are going to power
STEP 2: Construction
I first bought 1 of the panels, the charge controller and the wire. I made brackets for the solar panels from whatever i had laying around. I made a steak for them and put them on the side of our house that gets the most sun(which is really important) i started out with a little 1800mah battery(shown in picture 1), as you would expect it didnt last long. I soon bough another one. It was the 8amp one( i got the 2 4.5amp batteries out of my old scooter. I then ran the wire from the solar panels throunf my window, under the edge of my carpet and to my solar controller. I hooked my batteries up and then hooked up the cigarette lighter sockets and plug the inverter in through one of the two. I let the batteries charge up and have been running lights and fans and charging whatever. If you have any questions leave a comment.
STEP 3: Updates!
12/3/13
I have since added many updates to my solar! I added a light in the battery compartment, have a second,bigger inverter, lots of lights and other cool things! I use this now to power my small led tv in my room, charge my electronics, run fans, an even run some ac lights! Oh yah, and I used it to run my alarm clock too. I also added a panel that I have switches on so I can easily disconnect any thing I have hooked up. If I add anything to the system, I simply add more switches to the plastic board! I added a wireless receiver and remote also so I can turn on a few of the lights with a remote!
3 Comments
Dr.Bill 9 years ago
I don't have access to the roof either but that's ok I'm moving soon.
nathconley 10 years ago
Dr.Bill 11 years ago
I have no yard.
https://www.instructables.com/id/12-Volt-PhotoVoltaic-Power-For-The-Tiny-Apartment/
