Home Sensor Station
Intro: Home Sensor Station
The motivation is simply the fact that reading the temperatures and humidity values from different rooms should be cost effective as cost multiply by room count. Fully assembled temperature and humidity units including batteries can be bought for fair prices in online shops.
example
- Wireless Technoline TX29DTH from amazon, they start at 15Eur per unit incl. shipping
These units send with different IDs on a regular basis at 868MHz. Measured values are
- temperature
- humidity
Multiple of them can be used with one receiving Home Sensor Station.
Home Sensor Station
Ingredients
- Controller Board (Arduino / CoPiino) (a)
- Wireless Receiver RFM12B (+5V tolerant spec) (b)
- Display SSD1306 (c)
Thats it!
Read next page for how to wire and program.
Notes:
a) You can use the Arduino or CoPiino. As the CoPiino has 4x more flash and RAM and can be used as RPI Hat, we suggest to start with the CoPiino.
b) Please note the similar RFM69CW receiver is only 3.3V - better use RFM12B as in this instructables :)
c) There may be different versions out there, the one in the pictures above is +5V tolerant - go for exactly this one it works great as you can see.
STEP 1: Wiring and Programming
Welcome back on page two - the last page. Because wiring the controller, receiver, display and programming is all we need to do to get it up and running.
1. Wiring
The wiring is best done initially on a bread board. The pictures above show the details. Please note that image colors and schematic colors do match exactly for ease of use.
2. Programming
A 100% tested/working Arduino Sketch can be downloaded below. It comes with support of three TX29DTH units.
Additional units can be added in the code as follows
void setup(void) { ... sensors.addSensor( 0, "Fridge ", 53 ); sensors.addSensor( 1, "Weather ", 18 ); sensors.addSensor( 2, "Dining Room", 42 ); ... }
0 ... is an upcounting number
"Fridge "... is the name of the sensor
53 ... is the ID which is used by the TX29DTH to send temperature and humidity values (see notes below to determine sensor IDs)
3. Notes
3.1 How to determine the ID of the TX29DTH:
The controller will receive all sensors in your home and display a RS232 / serial message like these.
Example:
(rs232)RX>End receiving, HEX raw data: 94 85 36 45 5D AA AA 0 0 F9 FD 37 BF FF D7 9F
(rs232)RX>:: 18 13 69 (rs232)RX> (rs232)RX>End receiving, HEX raw data: 9D 44 85 3C 77 AA AA 0 0 7F FF FE 7F D9 CF 2F (rs232)RX>:: 53 8 60 (rs232)RX> (rs232)RX>End receiving, HEX raw data: 9A 86 30 39 5D AA AA 0 0 1F 7F D7 BF FF EF FF (rs232)RX>:: 42 23 57 (rs232)RX>
The first number stands for the ID and the second and third for temperature and humidity.
3.2 Serial receivings
As the sketch is best used with CoPiino which has two serial interfaces vs. Arduino which has only one serial interface, we prepared the code to have all output on port "Serial1". Please note when using Arduino, you need to switch to port "Serial"
CoPiino
Serial1.println("*** LaCrosse weather station wireless receiver for IT+ sensors ***");
Arduino (modification of port number)
Serial.println("*** LaCrosse weather station wireless receiver for IT+ sensors ***");
3.3 Thank you
If you think this instruction was helpful -- let us know.
6 Comments
kingjohn77 3 years ago
Would such a solution also work on a raspberry pi?
I have one with a homematic RF module installed... (HM-MOD-RPI-PCB)
U-110 6 years ago
Hello
Problems with the display. Does anyone have an idea?
MoTinkerGNome 8 years ago
This is a great Idea, I have been looking for a project to use with my CoPiino. Keep up the good work.
tswaehn 8 years ago
we think CoPiino is cool because it will wear all Arduino stuff easily and at the same time be an Raspbery Pi Hat which stacks directly on Rothe RPI.... And it has much more flash and RAM compared to the Arduino UNO. But it's hard to actually transfer the message :/
GEF77100 8 years ago
RFM12B is 3.3v perhaps better to use RFM12 which is 5v compatible,
same for SSD1306 better to use module with level shifter like adafruit product:
https://www.adafruit.com/products/326
or to use 3.3v Arduino...
tswaehn 8 years ago
Hi GEF77100,
Yes, thanks for pointing this out. I should mention that we need 5V variants of it. I will edit my instructable.
