Home-Made Water Proof Laser Holder
11,810
18
9
Introduction: Home-Made Water Proof Laser Holder
Make a water proof laser holder that will allow u to shine a beam under water! Looks cools, water proof!, looks like a flashlight!
Also visit my friends Home-Made Collimator Instructable: https://www.instructables.com/id/Home-Made-Collimator/
He gave me the idea to make this laser holder, and he gave me the 5mW laser.
Credits to VCW
Step 1: Gather Materials
1. mini maglite (water proof holder)
2. laser (i used a wicked laser core from: http://www.wickedlasers.com)
3. expo marker (extender)
4. plumbing tape (sealer)
5. thread seal tape (sealer
6. saw (cut stuff)
Step 2: Disassemble Maglite
There are three parts of the flash light I will be referring to:
1. tail
2. body
3. head
1.On the tail you will need to remove the spring and the extra bulb, you wont be needing those. (refer to image #2)
2. On the body you will need to take out the bulb and the black bulb holder. (refer to image #3)
3. On the head you will need to remove the reflector. (refer to image #4)
Step 3: Cutting Time!
(refer to image)
The rim is blocking the laser's path, so get a mini saw and drill the side till i become flush or almost flushed with the insides. A drill is also possible if you can find a big enough drill bit.
(video is to explain how i drilled the rim)
(of course it takes some time to drill the rim, took me about 5-10 minutes)
Step 4: Expo
Make some measurements, and cut the expo maker at the correct spot.
**make sure to use the side of the marker that is thiner**
Apply the thread seal tape on the end of the expo maker you will put into the flash light. Shove the marker into the end of the body. Use the pipe tape and seal the expo maker to the flash light.
Then, get the tail and apply the thread seal tape on the tail. you can screw the tail into the expo maker. Then use the pipe tape to seat the tail to the expo maker.
Step 5: Finish!
You are now finished!
Screw in everything, and submerge in water before putting the laser in the flash light.
When you know that water does not leak, you can put the laser in the flash light via the top.
I used a piece of tape to hold down the bottom while it is in the maglite.
Step 6: **Tips and Tricks**
1. If the laser is shaking around when you shake the flash light up and down, you can shove a cotton ball down the body to the tail so the laser can rest on it.
2. Spray painting the flashlight make it look like a real flashlight.
3. On the body use a file and file the rim, so it wont scratch up your laser.
4. Rating me positive will improve your laser!
5. Comment me and tell me how i can improve this instructable or how to improve the flashlight holder or some tips and ticks
The Instructables Book Contest
Be the First to Share
    • New Year, New Skill Student Design Challenge
    • Anything Goes Contest 2021
    • One Board Contest
      One Board Contest
    9 Comments
    bug on fire
    bug on fire
    Reply 13 years ago on Introduction
    I think that would actually work. Maybe us 2 condoms just in case
    GorillazMiko
    GorillazMiko
    14 years ago on Introduction
    Awesome idea, pretty cool and easy to do, I will have to try this out if I get a laser, then I can make some pretty awesome videos. Nice job.
    vcw
    vcw
    I have an idea to make the laser have a On/Off feature, try keeping the spring in the cap of the laser, and have the spring come in contact with the battery and the side of the laser. That way when you put pressure on the spring, it will somehow turn on the laser.
