HomeMade Modern DIY Concrete Nesting Tables
Intro: HomeMade Modern DIY Concrete Nesting Tables
I made these concrete nesting tables using nothing but Quikrete and LEGO bricks. I love how these concrete tables show the texture from the LEGO. I was skeptical about how well this idea would work, but everything went smoothly and Lego formed concrete is my new obsession.
STEP 1: Supplies + Tools
LEGO Bricks
Available at Amazon
I used the classic LEGO bricks to make the mold. I raided my parent's attic to retrieve my childhood stash and purchased a few new sets. Purchasing all new bricks for this project might be a bit expensive, so I'm working on a post showing how the nightstand could be cast in sections to reduce the amount of LEGO needed.
3/4" Melamine Board
Available at the Home Depot
Melamine board is particle board with a smooth laminate surface. It's a great product for making a concrete form work. I bought a 4' by 4' sheet and had four 2 1/2" strips cut at Home Depot.
Quikrete Countertop Mix
I prefer the Commercial Grade Quikrete Countertop Mix for these type of projects but Quikrete 5000 will work just fine as well.
Hot Glue Gun
I used a hot glue gun to glue the LEGO bricks to the board. Don’t worry – the glue will peel off later.
STEP 2: Layout the Mold
STEP 3: Mix + Pour the Concrete
STEP 4: Level + Smooth
STEP 5: Let the Concrete Cure
STEP 6: Remove the Mold
STEP 7: Clean the Legos
STEP 8: Finished (+Bonus Project)!
Good luck making your own concrete nesting tables and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more DIY ideas and projects, visit us as HomeMade Modern.
BONUS PROJECT!
8-bit video games and LEGO remind me of my childhood. This mini project was an experiment in making molds for concrete inspired by 8-bit graphics.
Get Complete Visual Step-by-Step Instructions at Stellar.
12 Comments
poofrabbit 9 years ago
Congratulations on being a finalist in the Concrete and
casting contest! Best of luck to you!
mastersoncraft 9 years ago
Not only is the project cool, but your video is really well done. You inspired me to have a go too.
Making two tables in one go is very smart.
mrandle 9 years ago
You could use a lego/ wood hybrid. Seems like alot of work to only have a pattern on the one side. Almost all the pattern is from the grey piece on the bottom that connects all the legos. I do like the idea of an almost infinitely reusable concrete mold. I'm wondering if you could use the foam for the sides like you used in that one project with the big planter with the drain in it.
flavouredginger 9 years ago
NOBODY PANIC!
he used the lego's again to make the nightstand..
this looks really cool and I absolutely adore nesting tables.
congratulations homemademodern on an awesome instructable.
flyguyb35 9 years ago
A V.E.R.Y. light dusting of the legos with a vegatable oil cooking spray and a wipe down with a paper towell will make them come free of the concrete instantly. It works on highway paving forms so it ought to on leggos
For those in JCook20's camp...Sloshing the afore mentioned oiled leggos in a pan of water with dish detergent and rinsing them well will probably have the leggos much cleaner that they were in the toy box. One should also investigate the colors Sakcreet has available. Red, blue, yellow, brown, & black are a few that are available. Using the fiber mix cement will make a much stronger unit.--when cured use a torch to clean off the fuzzies
simotoni 9 years ago
Bravissimo!!!!
Contentment 9 years ago
How is this a waste of Lego? He clearly retained the bricks used and could use them again or simply play with them. The tables are also quite clever, so again, why the negativity? Pointless criticism is beneath you, or it should be.
Suslee 9 years ago
Can this be done with hypertufa?
Danger is my middle name 9 years ago
This is awesome! You should enter it in the concrete and casting contest that's going on right now! https://www.instructables.com/contest/concrete2014/
rpost 9 years ago
Muhaiminah Faiz 9 years ago
That's a lot of hard work and the nesting tables turned out great!
