Introduction: HomeMade Modern DIY Copper Coffee Maker
This is the first episode of our “CoffeeScapes” series that will feature different ways to make the things that make our coffee. The copper pipe pour over device is held together with epoxy, so soldiering equipment and skills are not required. Because copper pipe can be cut with a tube cutter, this project can be made without a single powertool. I've included links to the filters and funnel that I used down in the supply list. This is a really easy project and makes a great gift.
Step 1: Supplies + Tools
1/2" Type M Copper Pipe (5’ length)
Type M copper pipe is thinner and easier to cut than the heavy duty types like type L and is perfect for applications like this. You only need about 2 feet but a 5 foot length was what I found at Home Depot.
1/2" Copper Fittings
Make sure that the fittings are the right size for the copper pipe you select. You'll need:
2 T-Fittings
3 Elbows
2 End Caps
Glass Funnel
I used a 100mm glass funnel to hold the coffee filters.
Steel Wool
I use #0 grade steel wool to clean the copper pipe and fittings.
2 Part Epoxy
I used a 2 part epoxy to fasten the copper pieces. Soldering it with a torch would be better, but is more difficult and requires additional tools.
Chemex Coffee Filters
Chemex coffee filters work well. If you get ones that are too big, it's easy to cut them down with scissors.
Rigid Tube Cutter
Step 2: Cut the Copper Pipe
Copper pipe is really easy to cut and doesn’t require powertools. I used a tube cutter to score a line and then simply snapped off the pieces by hand. A pair of pliers can be used to help get a better grip, but make sure you don’t scratch the copper too much with the jaws of the piers. You can wrap the copper with a rag to protect it before gripping it with the pliers. The length of the pieces depends on how tall of a cup you plan on using, so be sure to measure your cup height and the height of your funnel before cutting the pieces.
Step 3: Clean the Copper
Once you have the pieces cut, clean them with steel wool.
Step 4: Scratch
In order for the epoxy to get a good grip on the smooth copper, I scratched the ends of the pipes with 80 grit sandpaper. I check the fit of the fittings first so that I would only scratch the part of the pipe that would be hidden inside the fittings.
Step 5: Mix + Glue
Mix the 2 part epoxy together per the manufactuer's recommendations and apply to the ends of the pipe. Assemble the coffee maker and use blocks of wood to hold it in the right position while the epoxy sets.
Step 6: Wipe Away Excess Epoxy
Use a rag to remove epoxy that may have squeezed out during assembly.
Step 7: Wait Then Clean
Once the epoxy has set, you can do a final cleaning and polishing with steel wool.
Step 8: Add the Funnel + Make a Cup!
Insert the glass funnel into the top T-fitting and you're ready to add a filter, coffee grounds, and hot water! I used Chemex filters but accidentally bought the large ones, so I had to use scissors to cut them down to size.
Good luck making your own copper coffee maker and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more DIY ideas and projects, visit us at HomeMade Modern.
4 People Made This Project!
- Kcl989 made it!
- the_yellow_ardvark made it!
- asphalt made it!
- GeekTinker made it!
66 Comments
4 years ago
Love this, will have to put it on my list of things to do.
6 years ago
beautiful, but where do you find the glass funnel?
6 years ago
is it not dangerous to use copper? the coffee as food comes directly in contact to the copper tubings...no health risk issue here about heavy metals?
Reply 6 years ago
copper pipe has been used in the UK and Ireland as water pipe for centuries man. there is absolutely no dangers
Reply 6 years ago
Accept coffee is acidic and leeches copper from the pipe. However, coffee never touches the pipe.
Reply 6 years ago
nope if you look closely the glass funnel extends a few inches below the copper. this is more a nice holder for a simple pour over coffee.
I would be more concerned about the epoxy since most pipes in your home are coper. now there would be a concern since you may be changing the acid levels and with and heat that may be in issue but not a big deal since this one you are only coming into contact with glass and paper.
Reply 6 years ago
The water lines in your home are most likely copper. Do you worry about drinking water that comes from the faucet?
Reply 6 years ago
Water is not acidic, coffee is. The copper leached is unhealthy, but its not touching the coffee so meh.
Reply 6 years ago
You drink water from copper pipes
Reply 6 years ago
This.
Also, at no point is there anything you are consuming coming in contact with the copper....
6 years ago
It's well known there are 2 foods that can be safely cooked on copper: chocolate and coffee.
6 years ago
Just use the tubing cutters to cut the pipe, no need to use pliers. Tubing cutters cut pipe.
7 years ago on Introduction
Isn't that rather a coffee filter holding device than an actual coffee maker? I mean... it does not make coffee, right? So one could argue that it could be easier to put the funnel right into a coffee jug where it belongs.
Yeah, why bother with filtering the coffee, or even putting water in it? Just eat the grounds and drink some hot water. :)
Reply 6 years ago
Eat the raw beans! It'll be nore time efficient and will make you tougher...
Reply 6 years ago
Why even grind it?
Reply 6 years ago
6 years ago
to all the health nuts complaining about this being dangerous or toxic. Let me just say how do you think water is delivered to your house? By Copper or cast iron pipes and if for some reason you are paranoid still about copper well then make it out of plastic or some other tubing. Wow its not that hard this is a great project I'm definitely making one out of copper.
6 years ago
Keep in mind that there are great foam insulation options made for copper pipe to insulate it in ceilings or crawl spaces. The stuff is similar to the Pool Noodles found at Wally World, etc. Cut a few short pieces to insert the standing or supporting copper pipes into, and Voila, now it takes a coffee filter enclosure, pasta colander or other accessories. AND, it will keep them from slipping all over the place as well. Popular colors are gray and black:-)
Bummer, I was considering something similar as my next video. Oh well. Nice job!
