HomeMade SlowCooker
Intro: HomeMade SlowCooker
For a long time now I have wanted to own a SlowCooker. Unfortunately, I couldn’t decide on which one I should get. I like the expensive ones where you can set the temperature digital but, being Dutch, there is no way I'm spending that kind of money!
Now I have a little more time on my hands due to the COVID-19 crisis, I decided instead to just make one myself. I had this ceramic hot plate lying around which I was already using for my pot roasts. And after diving into my parts collection, I dicovered all I needed to buy was a 4 euro temperature sensor!
It is great for making stews and pot roasts, or tempering chocolate au bain marie!
STEP 1: Hooking Everything Up
If you have acquired all of your components, it is time to connect it all together. If you like you can set everything up on a breadboard first, or go straight forward to building up your SlowCooker. In any case, I’ve included a Fritzing diagram to explain how to connect all the parts. This is my first try at Fritzing, so I apologize if it’s not entirely clear…
In real life I connected my 12V power supply directly to the power socket with switch, so that everything can run off of 1 plug. I use the switch to turn off the device when it’s not in use.
Furthermore, I’ve soldered the resistor and the thermometer to a small piece of PCB board.
If you have got everything connected correctly upload the code to your
Arduino using the Arduino IDE.
n.b. In the pictures you can see I started out with an Arduino Nano but I forgot to unplug it while I was soldering, so I accidentally fried that one... Oh well...
STEP 2: Housing
Finally, you need some form of housing for all your parts. I chose to make a cube (120x120x120mm) out of 9mm multiplex with holes for the various external components. I have to admit: it’s not my best work, it's a little tight, but it does the trick.
A plastic container might also do well as a housing, but that’s up to you!
After you've put everything in your housing it's time to start cooking!
Good luck and have fun!
6 Comments
foggy34 4 years ago
DandyThen 4 years ago
Alex in NZ 4 years ago
jessyratfink 4 years ago
