HomeMade Weighing Scale Machine
Intro: HomeMade Weighing Scale Machine
Made a Weighing Scale with a capacity of 200kg. the structure was made from steel laying around. the whole build took 2 days to complete, as the paint took much longer to dry. Arduino was used in this project,
this project involved some metal work like welding and girding to construct the structure of the weighing scale.
STEP 1: Components and Wiring Diagram
Components used:-
Arduino
LCD 16x2
Hx711 Module
LoadCell 200kg
5volt power bank
and some wires
any doubt about the wiring let me know.
STEP 2: Arduino Code
simply go to http://textuploader.com/dou7o to copy the code for arduino
/* MakerMan Weighing Scale Ver: 1.0
This example code uses bogde's excellent library: https://github.com/bogde/HX711 bogde's library is released under a GNU GENERAL PUBLIC LICENSE
The HX711 does one thing well: read load cells. The breakout board is compatible with any wheat-stone bridge based load cell which should allow a user to measure everything from a few grams to tens of tons. Arduino pin to HX711 A2 -> CLK A1 -> DAT 5V -> VCC GND -> GND
The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power should be fine. */ #include
#includeint button1 = 9; int press1 = 0;
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
HX711 scale1(A1, A2);
#define MAXFLT 8 // 24 bit resolution is 7 digits
void setup() { lcd.clear(); lcd.begin(16, 2);
lcd.setCursor(0, 0); lcd.print(" Weighing Scale "); lcd.setCursor(0, 1); lcd.print("----MakerMan----"); delay(3000);
lcd.setCursor(0, 0); lcd.print("--Place Weight--"); lcd.setCursor(0, 1); lcd.print(" ..... kg ");
scale1.set_scale(-11410); // BUG: calibrate the scale (higher number, lower reading) scale1.tare(); // reset the scale to zero
pinMode(button1, INPUT); digitalWrite(button1, HIGH); //enable pullups to make pin high
void loop() { float r; char buf[MAXFLT + 1]; r = scale1.get_units(5); // average 10 readingslcd.print(scale1.get_units(10), 3); // average 10 readings Serial.println(dtostrf(r, MAXFLT, 3, buf)); lcd.setCursor(0, 1); lcd.print(dtostrf(r, MAXFLT, 2, buf)); // average 10 readings, approx 1 second
{ press1 = digitalRead(button1); if (press1 == LOW) { scale1.tare(); } else { /// do nothing } } }
STEP 3: Video of Weighing Scale
here is the video of the whole build process, where i start with constructing the frame for the scale and to the end integrating arduino. the scale is simply powered by an old power bank.
danielfik 5 years ago
thankyou
