Homemade Cutaway Guitar - of an Existing One!
Intro: Homemade Cutaway Guitar - of an Existing One!
These are instructions how to make a homemade cutaway guitar of an existing one.
CAUTION: Not for beginners!
You must be able to handle with wood etc.
Get a guitar
http://www.ebay.com
http://www.ricardo.ch
A Guitar
http://en.wikipedia.org/wiki/Guitar
General documentation
Acoustics for violin and guitar makers
http://www.speech.kth.se/music/acviguit4/
Get a guitar
http://www.ebay.com
A Guitar
STEP 1: What You Need
Ok, here is what you need:
1 existing Guitar. (cheap one!)
1 Hotair gun
1 Saw (here japanese)
1 thin small saw (here a automatic). Needed for make small radius cuts. [german: Um sehr enge radien zu sägen.]
1 glue
1 paring chisel (small one, here 6mm) [german: Stechbeitel]
+ Lot of patient and time ;-)
1 Hotair gun
1 glue
STEP 2: 1st Do Checking and Draw a Mask
First do checking if the cut is practical. If you can do it.
Check for parts witch must be cut off.
Check for parts inside the guitar.
Check also witch side. Left hand or right hand guitar differs!
Prepare a mask, a template. With paper or with transparent foil.
Draw with little dots the "cut route" on top and on bottom of the guitar.
Make sure, that you will saw better less material then too much!
STEP 3: CUT!
Do the cut! - But think better twice then ... cut away material that you need (as I did unfortunately)!
1st the top, then the bottom, then on the neck. NOT the side! (The side will be bent.)
STEP 4: Prepare for Bending
So then, do preparation for bending the body sides (ribs). [german: Zarge]
Clean up.
Remove the paint (german: Lack) on the body side.
As shown in the picture.
Depending on what (german: Zargenverstärker ) you have:
CAUTION: Do not bend the body side if dry!
Clean up.
- cut them, if not already is so. As shown in a picture below.
STEP 5: Bend
Bring water on the body side. With a spray.
After a minute or so, the body side is wet and very easy to bend.
So you can just "open" the guitar, so that you can look inside it :-)
STEP 6: Prepareation Again (for Definitive Bending)
Do some preparation on the bottom.
The body side will take place *inside between* the bottom and the top.
So, remove some wood (german: Verstärker oben und unten), if they disturb.
See pictures below.
STEP 7: Bend!
This is one of the most critical part.
- Put water again on the prepared body side.
- You should be able to bend the body side very easily.
- Maybe some heated up air is required, maybe not.
- Make sure, that the body side does not move away.
You can also see the missing wood of the bottom side. (So better cut away less wood.)
But, anyway does it looks like a cut away right now?!
STEP 8: Glue and Repair
Glue
- I used simple white glue. PVAC. (german: Schnellabbindender Weissleim)
- So in 5 minutes, the glue is dry.
Repair
So here the reparation.
- Add wood that was cut way before.
- Glue it.
- Cut away wood. And do preparations with sandpaper.
26 Comments
davidapfeiffer 6 years ago
No bending wood. I used popcicle sticks years ago to fill the cutaway area on the body, some wood filler over them, and then repainted guitar body. Was able to cover an extreme cut easily. Looked great.
sartor 13 years ago
A test to see how much the soundboard's resonance affects the sound of a guitar: put a guitar on your lap and strum the open strings. Listen to the vibration, sustain, overtones, etc. Now press your other palm down on the soundboard (not too hard, as you don't want to damage it) and strum again. Hear the difference? Try this with the sides and back, too.
If you MUST have a cutaway (do flat-top guitars sound good that high up anyway?), consider a Maccaferi-style that's not too invasive:
http://upload.wikimedia.org/wikipedia/commons/7/7c/Guitares_type_Selmer_Maccaferri.jpg
looperted 13 years ago
LasVegas 17 years ago
michi 17 years ago
mrmath 17 years ago
michi 17 years ago
Synthezoid 16 years ago
Strings and connection points affect volume, partials and sustain greatly, but not so much the overall tone (at least, as long as you're not comparing strings with two completely different vibrational properties, like nylon vs. steel and wound vs. unwound or roundwound vs. flatwound.) I use the exact same set of D'Addario medium strings on my old beater Epiphone and my beautiful tobacco sunburst Simon & Patrick dreadnaught, but both guitars have a *completely* different tone from each other, owing to their different construction.
A lot of this can be found right in the "part 6" pdf on the acoustics page you linked to above (http://www.speech.kth.se/music/acviguit4/). (See in particular where it talks about how important the back and neck of the guitar can be to the resonances that shape the tone.)
Generally speaking, the smaller "bulb" of the guitar's body (near the neck) produces a high-frequenecy resonant peak, and the bigger bulb produces a lower peak. Together these produce a full sound. (This is why you rarely see "teardrop" shaped guitars, like an "A-style" mandolin.) Change the volume of one part of the cavity and you change the mass of the air that occupies the body, which shifts the resonant peaks and changes the tone. Ditto for removing mass or changing the shape of the front or back. Even the mass of the guitar's neck makes a difference. (See the PDF again. Or, if you want to try an expensive experiment sometime, stick a Stratocaster neck on a vintage Les Paul and see what it comes out sounding like.)
The reason cutaway guitars are more expensive than non-cutaway guitars is because of the extra work required to compensate for the acoustical losses of changing the body cavity volume and the area of the top, the necessary extra load-bearing bracing for the neck, etc. True, the losses may not be that huge to untrained people's ears, but they are there, and in a fine guitar it can create a noticeable difference.
These are not my opinion, they're simply the scientific facts of how sound production works in a guitar.
If your guitar sounds the same to you after doing this mod, I'd argue you probably have either a pretty cheapo guitar or a fairly untrained ear. Nothing wrong with that, except that it's incorrect to say on the basis of it that this won't change your guitar's tone.
The upshot is - thanks for this instructable, it's great (and a bold move!) but people should be warned not to do this to an instrument they care about, because the results will be unpredictable. Real cutaways are designed much more carefully than this, they're not just a regular guitar with a chunk taken out..
RC-Roi92 14 years ago
infoplus007 15 years ago
trebuchet03 17 years ago
Instrument materials, shape, construction will play a huge role in resonance (as you probably know). Sure, you can get decent sound out of almost anything by being a good player and using quality (not necessarily expensive) consumables. But comparing the same consumables on two different designs can show a big difference, if you know what to listen for :P But don't get me wrong, I spent a decent amount of money on a euphonium mouthpiece :P
Kinda like speakers.... Pay hundreds for the driver speaker... and a few dollars on an enclosure -- and you're not going to get as great a sound out of it. The Bose wave thingamabober is all enclosure (instrument), less driver (strings) - for example.
Nice instrucable though :)
binnie 17 years ago
carlos66ba 17 years ago
michi 17 years ago
Yes sure. But on a existing one, the cutaway will not take affect strings and connection points etc. - Only shape and volume a little bit. So, the sound is nearly the same as before.
In fact, I was able to clean up and finish some wood splitting inside the guitar, witch did some noise before. ;-)
Wario 16 years ago
Ramnosity 16 years ago
Wario 15 years ago
downhilldman 15 years ago
Wario 16 years ago
