Homemade Foxtail-type Toy
Intro: Homemade Foxtail-type Toy
This is a fairly simple way to reuse an old tennis ball to make a fun and entertaining toy. If you've never played with a Foxtail, they are surprisingly fun. They're great for playing games like 500 and Flyer's Up, and dogs just love them.
STEP 1: What You'll Need
An old tennis ball
Some scrap fabric (preferably lightweight nylon)
Sewing machine
Dental floss
Sewing needle
Needle-nose pliers (maybe)
STEP 2: Cut the Fabric for Tail
You need a 30-inch long piece of fabric that is 9 inches wide on one end, which tapers (on center) to 2 inches at the other end.
I sewed various pieces of scrap fabric together so there were three separate sections, and then trimmed the whole thing to the right dimensions. (An easier way would be to just use one whole piece of fabric to begin with.)
Having sections in the tail with varying colors is nice if you plan to play a game like 500, because it allows for different point values based on where you catch the foxtail. For example, catching the ball itself is worth 25 points, the first section is worth 50, the second section is worth 75, and smallest tail section is worth 100. (I recommend this point value arrangement, as the farther from the ball you try to catch it, the more difficult it is.)
("500" is a game where one person throws (or bats) a ball to a group of people, and individuals try to catch the ball in order to get a specified amount of points. The first one to reach 500 points becomes the thrower, and everyone else's points go back to zero. That's the basics--there are lots of variations.)
STEP 3: Sew the Tail
Fold your triangular piece of fabric in half lengthwise, and with a 3/8" seam allowance sew it closed along the long side, and across the short, narrow tip of the tail. (Don't sew the wide end shut!)
(You may notice that your piece of fabric is now a right triangle. If you're worried that it will sit crooked on your tennis ball, you can trim off a little from the open end to make it into a nice isosceles triangle (picture 2). Otherwise, don't worry about it. It won't make much difference anyway.)
Now fold the tail right-side out.
STEP 4: Insert Tennis Ball Into Tail Section
You now need to place the tennis ball into the opening of the tail. This might be a little tricky, but you'll get it.
On the open end of the tail, fold the top inch or so down into the tail section, and gently place the ball into the opening. Carefully pull the fabric up over the tennis ball a little at a time, working your way around the ball. It should be nice and snug. You don't want the tail to cover up more than about half of the tennis ball.
STEP 5: Stitch the Tail to the Tennis Ball
You will want to use a strong needle, and perhaps a pair of needle-nose pliers to help push an pull the needle. Make sure to stitch through just a little bit of the tennis ball felt with each stitch. Don't puncture the tennis ball with the needle. That's not the intention here!
In picture 1, you can see that the tip of my needle is slightly bent. This makes things a little easier, so you may want to use those pliers to give your needle tip a little bend.
Picture 2 shows a good way to tie off the first stitch so the thread will never pull through and begin to unravel. Stitch your way around the tennis ball, tie it off really well, and you're done.
That's it! Go outside, swing it around a couple of times, and let her rip!
(Be sure to let me know what you think!)
19 Comments
Bosun Rick 9 years ago
Child-Proof / Safety-For-All version of Yard Darts!!
friendlysinger 12 years ago
lburke3 12 years ago
0jack 13 years ago
Brother_D 15 years ago
WhyHello 13 years ago
and a husky
and a german shepard
and a puppy
yeah these are great X3
(fetch if u havent figured it out
notker 14 years ago
Kryptonite 15 years ago
idogis1 15 years ago
SWV1787 14 years ago
I am also including it in a Christmas gift since our family agreed to hand make gifts for our Christmas gift exchange so keep an eye out for my Instructable on a huge toss game mash-up...
eulaliaaaa! 14 years ago
maxpower49 15 years ago
Jawsh 15 years ago
bumpus 15 years ago
Lftndbt 15 years ago
frollard 15 years ago
I'd like to note that tennis balls are pressurized, so puncturing all the way to the center *could* be a bad thing, but in this case its just being used as 'weight' for foxtail games. If you want to retain a lot of the bounce of the tennis ball, make sure you only go partway into the rubber of the ball!
5* from me.
