Homemade LM317 Bench Power Supply
Intro: Homemade LM317 Bench Power Supply
This is my first real project in electronics! I started by looking at the schematic and scratching my head a lot then just went for it!
I put the bits and bobs on the board and soldered them into place, wasn't really sure how or where to put the bits. Then i started soldering the wires as in the schematic that's easier said than done! after a few hours things started to come together, i finished the board and tested and to my amazement the psu worked! i would like to show afew pics and the schematic i used.
10 Comments
sprasanna3 7 years ago
Hi
I have a problem,after giving all the connections as per the diagram,the output voltage has only a minor difference(+/-2-6) even is the variable resistor is adjusted.
Any idea what may be the problem?
Hammerhead46 9 years ago
I notice on the schematic your note " DO NOT CONNECT THE GROUND OF THE AC POWER TO THE COMMON OF THE POWER SUPPLY" .
Looking at the photos I do not see that ground wire at all.
I would connect the AC ground to the case of the power transformer, so that if the transformer should ever short out internally you would not have a hot transformer when servicing.
Also I do not see the 0.5A fuse shown in the schematic mounted anywhere, this I would always recommend be mounted to a externally (See Photo) accessible fuse holder with the center connector connected to AC HOT and side connector to transformer.
That way you cannot come in contact with the HOT AC while changing the fuse.
joshuam511 10 years ago
Bio961 11 years ago
GamerM 11 years ago
Cause it gives max 3 Amps.
LM317 has max of 1.5 Amps.
And yes you can use 24V with no problems.
Just make sure you use a cooler.
pfred2 11 years ago
Your first supply came out a lot better than my first one did. When I made mine there weren't any personal computers though, so I guess I get a little slack there.
Lectric Wizard 11 years ago
Wizzkid1984 11 years ago
