Homemade Mini Aquarium From Lamp Bulb
3,889
68
35
Introduction: Homemade Mini Aquarium From Lamp Bulb
About: I am very happy to learn new things. and I am very happy to see the work of photography
in my home many old lamp bulb, and i have idea to recylce that to make a aquarium for Betta fish.
and i gift for my younger brother. maybe that look like special. :)
Step 1: Material and Tool Needed
Material and tool needed easily obtained
Material :
1. old lamp bulb
2. plywood
3. hot gun glue
Tool :
1. pliers
2. hacksaw
3. plywood saw
Step 2: Make Hole on Top Lamp
warning. !!
you should do this in sink in the kitchen cause it's make you easily move crack glass to trash and make you safe if the lamp bulb crack.
first time cut the edge top lamp bulb using hacksaw and then after opened, use pliers to cracked valve (view picture tag red circle). after crack valve make the hole bigger, if you have glass cutter that make easily but if not have you can use pliers to make hole bigger by way in pliers the edge very carefully. after make hole bigger get out parts of lamp bulb and clean white coating using old tuth brush or whatever you can use, and then keep a safe place.
Step 3: Make a Box for Holder
for holder lamp bulb i'm make a box cause easy.
before make a box you must first measurement lamp bulb and design a box what you like, and then cut plywood, make hole and raft with glue, in my case i use hot gun glue because practically. now is the time to buy Betta fish.
Step 4: What You Like to Place.
you can place on the table or you can place in a corner of the room, whatever you
Leftovers Challenge
Leftovers Challenge
Homemade Gifts Contest 2015
Be the First to Share
    • Lamps and Lighting Contest
    • Back to School: Student Design Challenge
    • Plastic Challenge
      Plastic Challenge
    35 Comments
    Glenn781
    Glenn781
    3 years ago
    you need to burn in hell for keeping a fish any fish in that small of a container
    IHGlife
    IHGlife
    3 years ago
    unless you have a realy big lightbulb then a betta is fine
    IHGlife
    IHGlife
    3 years ago
    it might be goof for betta fry cuz they are soo small but dont ceep adults it could die
    it is good for shrimps and snails though.
    Builders Shed
    Builders Shed
    5 years ago
    Poor Betta :( .. You shouldn't put a fish on that bulb.. Ikan nya kasian :(
    Scotte678
    Scotte678
    5 years ago
    For a fish no, for Mabey like one of those see through shrimp, yes
    Kreat0r
    Kreat0r
    5 years ago
    more like a Micro aquarium..hwo s the fish gonna move in it man.
    Pantsformer
    Pantsformer
    5 years ago
    I've done these before. And please, under no circumstance, put a fish over an inch in there. It would be a cruel and horrible life for the fish, but i do suggest small brine shrimp, snails, and other small aquatic animals and plants.
    Naturelover64
    Naturelover64
    5 years ago
    Really hard to understand, because the wording and the one continuous sentence. Plus, the poor fish has no room. Maybe an underwater terrarium?
    MatthewS3
    MatthewS3
    5 years ago
    This will kill a fish. Do not build this for fish. Might be great for plants though.
    jakesplacebc
    jakesplacebc
    5 years ago
    Absolutely cruel. No fish should ever be put into an environment this small for any period of time. Betts fish for example should never be placed in an aquarium less than 5 gallons. It's like putting a baby in a playpen for years.
    silent1mezzo
    silent1mezzo
    5 years ago
    This is horrible and should be considered animal abuse.
    gorziks
    gorziks
    5 years ago
    Haha sorry dude I just have a fish tank and care about fish, it was just a suggestion i didnt think all these people would get on your case
    gorziks
    gorziks
    5 years ago
    Thats cool and all, but the poor fish has no space
    ir_One
    ir_One
    Reply 5 years ago
    no the space for fish not poor, i'm use lamp bulb bigger. high 7 inch and diameter +- 3.35 inch. and my little fish free
    ashleyjlong
    ashleyjlong
    Reply 5 years ago
    Sorry, but these commenters are correct to state that this is not enough room for a fish to live a quality life. My mom has had an aquarium business most of my life, so I'm familiar with appropriate gallons per fish. Experts and hobbyists alike agree that one beta needs at least 1 gallon of water. Living in a bulb (even one that is 7 inches) would be like confining you to a bathroom for your whole life. http://www.bettafish.com/showthread.php?t=76504
    I appreciate the aesthetic and the creativity, but this is not proper animal care. Consider using the bulb reuse idea for an enclosed aquatic plant ecosystem instead :) That would look very nice!
    mrsnone
    mrsnone
    Reply 5 years ago
    I like that idea.. with the aquatic plant or terrarium of some sort.. but wonder if the glass would be heavy enough to support all that?
    ashleyjlong
    ashleyjlong
    Reply 5 years ago
    Sure --valid concern. Not a full environment, but something simple like moss balls or small herb clippings that take root in water.
    ir_One
    ir_One
    Reply 5 years ago
    thanks for suggest
    End3rS14yer
    End3rS14yer
    Reply 5 years ago
    What? Dude, first off, how did you even get that poor fish in there? Second off, how do you filter the water? The waste will build up eventually. It was a nice idea, but maybe put something else inside. Also, it's much easier to clean the inside of the bulb with just some warm water.
