Homemade Mini PCB Drill
Intro: Homemade Mini PCB Drill
Building a home made drill machine for the PCB.
STEP 1: Making Video
You can watch the video for making of the drill or continue reading to make one for yourself.
You Can Subscribe To My YouTube Channel Here : https://goo.gl/ctc8l9
STEP 2: Things Required
1. 12 Volt DC Motor
2. PVC pipe (Which should fit the motor)
3. Perfume cap
4. PCB Drill Chuck
5. PCB Drill Bit
6 Chuck Key
7. Switch
8. Adhesive Paste
9. Insulation Tape
10 Scissor
11 Wires
12 12 volt Adapter or 9 volt Battery
13. Solder Gun, Solder Paste & Solder Wire
14. PCB board to test
STEP 3: Construction
Connect the wires to the Motor & Switch
STEP 4:
Make a hole in the perfume cap to insert the switch
STEP 5:
Make few holes to let the air flow to cool the motor
STEP 6:
Cut the adhesive paste and apply on the inside of the PVC pipe & insert the DC Motor
STEP 7: Wiring
Connect the wires as shown in the wiring diagram
STEP 8:
STEP 9: Finished Images
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US:
Drill Chuck : http://amzn.to/29Y0lfH
DC Motor : http://amzn.to/29Qg9lO
Switch : http://amzn.to/29YN5L4
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
PCB Board - http://amzn.to/2abRXw7
Insulation Tape - http://amzn.to/29YNZax
Scissor - http://amzn.to/29Y1K65
Super glue - http://amzn.to/29Wvpi1
Amazon India:
Drill Chuck : http://amzn.to/2a0CFcW
DC Motor : http://amzn.to/29KPwOx
Switch - http://amzn.to/29SqL6Z
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
PCB Board - http://amzn.to/29Ged2O
Insulation Tape - http://amzn.to/29HGzpJ
Metal Paste - http://amzn.to/2a9Tgy5
Scissor - http://amzn.to/29P2ECE
Super glue - http://amzn.to/29HHbvK
Follow Me On :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
THANK YOU FOR READING !!!
12 Comments
UtkarshVerma 7 years ago
For a simpler method try this:
https://www.instructables.com/id/Handheld-PCB-Drill/
VishalK96 7 years ago
nava1uni 7 years ago
What is the power source.
DIYTechStudio 7 years ago
DylanD581 7 years ago
Great PCB Drill for DIY PCBs!
andrefierens 7 years ago
genius !
Ca. RAFAEL FELIXXO 7 years ago
excelente gracias
DIY Hacks and How Tos 7 years ago
Nice. DIY tools are a great way to build DIY projects
Thanks.
