Homemade Mini PCB Press Drill DIY Drilling Slide Mechanism CNC
Introduction: Homemade Mini PCB Press Drill DIY Drilling Slide Mechanism CNC
Homemade Mini PCB Press Drill DIY Drilling Slide Mechanism CNC very easy, You can Make it in home with
2 pcs 20 mm Linear Ball Bearing Motion Bearing CNC
2 pcs SHF20 Size 25mm Linear Rail Shaft 220 mm - 20 mm Linear Rail CNC Promotion 2 pcs SHF20 Size 20mm Linear Rail
Alumnium Alloy 6062 125 mm x 250 mm x 12 mm, Alumnium Alloy 6062 125 mm x 40 mm x 12 mm, Old motor take out from old hand Drill
Homemade Mini Press Drill DIY PCB Hand Drilling Machine here:
More Homemade Micro Vertical Milling Machine DIY Z Axis here:
Be the First to Share
    • Game Design: Student Design Challenge
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
