Homemade SNES Arcade Machine
Intro: Homemade SNES Arcade Machine
This is my second entry in the homemade arcade machines. A Super Nintendo in a bartop arcade machine. I'm now up to 3 machines. Some of these pics are also of the Sega Genesis Arcade machine that I did not make build pics for. My next machine will be an original xbox running MAME with hundreds of original arcade games.
61 Comments
PatrickF36 8 years ago
colossalman 7 years ago
I'm not the maker, but it looks like that monitor just has AV inputs on it.
https://cdn.instructables.com/FJA/BP3B/HPZMROMX/FJABP3BHPZMROMX.LARGE.jpg
elliot.humiston 9 years ago
I was wondering if you could list the general dimensions of this project? or maybe even a template???
djkurtz92 9 years ago
drew.selling.5 9 years ago
Love your work, they look awesome. I have no carpentry skills and lack the technological know how, but I am still having ago at building one. I have done a lot of research and Google brought me here. If you could just answer a couple of questions it would be much appreciated.
1. Where do you solder the ground wire to on the control pad board?
2. Did you use a separate ground wire for each button to the board or link them all with one wire then solder just that one to the board?
1. First I scrape off the graphite coating off of each button exposing the copper beneath. I then drillied small holes in each point to feed the lead wires through and bend to hold into place. Then I soldered.
2. If you are using Happ controls its just as easy to make a seperate ground wire for each because you'll need 2 wires per switch. If using the Sanwa version of the joystick, those are wired for a common ground so you could save some wiring and time. My preference is the Happ joysticks, I just like them better.
I hope this helps. The NES version machine build pics show almost everything you need to do to get a similar result. The game played great with that setup. I could still beat Dracula on Castlevania with that control setup.
Thank you for replying and sorry for all of the questions, but I really am that much of a novice.
What kind of paint did you use?
Did you use T molding for the edges?
Do I need a certain type of wire for the controls?
HI I AM SETH 9 years ago
1. Cool! I like those cabinets dude! I'm planning on making one with my Sega Genesis.
2. I live in CT also! (I saw the CT license plate hanging on the wall. I'm not a stalker!)
BrianC7 9 years ago
Awesome stuff!!! I'm looking to start a project similar to this but an all-in-one via emulators. Quick question that I don't think has been asked yet: where do you get your joysticks and buttons from? Thanks.
neonkid 9 years ago
Where did you get the decals made?
neonkid 9 years ago
Awsome, thanks
macaleese 9 years ago
Crafterkid123 9 years ago
Could this work with a gamecube/wii? I mean both are smaller than the snes so they have to fit right??
themacguru 9 years ago
