Homemade Sandblaster
Introduction: Homemade Sandblaster
This is the sandblaster I made from lpg tank and it cost me about 35$ . If you know welding its easy to make one.
Its useful to remove rust from old steel or coating , also you can use its to "draw" on glass , wood or plastic objects.
Lets see how I made it .
Step 1: Cleaning
Open the valve and let upside down for one day. Then remove the valve carefully and add water to clean the interior from the gas , you can repeat it to be sure.
Step 2: Welding
Next step is to drill the tank and welding all connectors and the base for the wheels .
Step 3: Parts
Next step add the safety valve, manometer, and ball valves on it .
Step 4: Painting and Test
Last step is to paint it and the sandblaster its ready for use.
Adding quartz sand 0.4 to 1.00 mm and set the pressure at 5-6 bar .
Important: Full face mask with filters, gloves and uniform to protect yourself .
Step 5: Video
https://www.youtube.com/watch?v=ha7bR4pqn94
Be the First to Share
    • First Time Author Contest
    • Meatless Challenge
      Meatless Challenge
    • Remote Control Contest
