Homemade Sling-Bow
Intro: Homemade Sling-Bow
In this instructable I will be showing you how to make your very own sling-bow. A sling-bow is basically a slingshot that's altered to shoot arrows. They are pretty powerful depending on what materials you use to construct them with, and can be made on a very slim budget. So without further ado lets begin!
STEP 1: What You'll Need
You'll need:
- A sling shot
- A golf tee
- An O-ring
- Two medium zip ties
- An old beat up arrow
- A few strips of duck tape
- Whisker biscut
STEP 2: The Sling Shot
The first thing you need to do is to prep the sling shot. The first step in doing this is to take off the existing elastic bands, and discard them. Next take your heavy duty replacement bands and trim them until there's 1 inch of band for every 5 inches of arrow. For example I trimmed my bands to 5 1/2 inches, and they work perfectly with my 25'' arrows. Next put your bands on and leaving a quarter inch to a half inch of extra band extending at the end. To test pull it back to it's max draw and have someone measure the distance from the pocket to the extra bit of band on the sling shot. You want this number to be less than the length of the arrow by one or two inches.
STEP 3: The Arrow Rest
The arrow rest is what is going to hold the arrow before and during the release. You want the O-ring, to be perfectly vertical, so to do that you first need to put one of the zip ties through the O-ring and then around the end tag of the elastic band like in the picture above. Don't tighten it all the way yet, we'll get to that later. Then next to get the ring to stand vertical you need to counter twist the other zip tie. If you are confused at this point just reference the pictures above. Now tighten the zip ties until the ring is right in the center, and vertical.
STEP 4: Optional: Whisker Biscuit
Attaching a whisker biscuit is optional, but will help your accuracy and help preserve your arrow fletchings. To do this put a rubber band around your O-ring using a small zip tie, like in the picture. Then slide your whisker biscuit into place.
STEP 5: Arrows
The arrows I use are just some carbon fiber arrows I out grew or some that just have bad fletchings. First you need to remove the fletchings and knock. The knock should pull out with a pliers, and the fletchings are easy to remove using a pocket of your hunting knife. You should by now have an arrow striped of everything except it's Insert.
STEP 6: Fletching the Arrows
To fletch the arrows I use duck tape. This is the best, cheapest, way I found to do it. First rip a section of duck tape about 2-3 inches long. Next crease the duck tape in the middle leaving a little bit not stuck together at the top. Then stick that part to the arrow shaft about 1 to 1-1/2 inches from the end were the knock use to be. You will get better flight and accuracy if you angle your vane's to make the arrow spin, but it isn't required for good performance.
STEP 7: Reapeat
Once you have repeated this to all three to five sides you are ready to cut out the actual shape your vane/feather will be. I like to use a downsized version of the original vane's shape, and make normally three of these.
STEP 8: The Nock
For this I found that hot gluing a golf tee into the shaft is the best way to go. Shooting arrows with the standard nock is OK but it seem to put more stress on your fingers, and can sometimes slip out. The last thing to do after this is to screw in your point. Now you're all set to shoot! I hoped you enjoyed this instructable and wish to see more in the future.
8 Comments
waz52 6 years ago
Hi, I would love the instruction on how to actually make the slingshot with the arm rest etc, our snowflake politicians banned them, would love to have a few made for a just in case event, we have compound and recurve Bows, heaps of arrows too
Thanks
MustaphaF 9 years ago
Mr. Brunner, Good instructable, clear and well-illustrated.I'm an old guy, but a newbie at this. Why do you have to re-fletch the arrow? If it's the size of the o-ring, could one just mount a whisker biscuit, and go with the original fletching? Thanks.
DIYWEAPONS 9 years ago
i will be posting a pvc 15 lb fishing slingbow along with 13 other instructables.
what draw weight is this as i am pretty sure for fishing you need at least 8 lb
Kayak Kid 10 years ago
I don't know the o-ring's size but i'd say maby 1 inch in diameter.
1KUSTOMLEATHER 10 years ago
MMedleyW 10 years ago
the_doctor7019 10 years ago
