Introduction: Homemade Small Cabinet With a Glass Door
About: Let's make something
I have a piece of transparent glass, which was removed from the broken scanner.
The size is a little larger than A4 and the thickness is 3mm.
It just happened to be used to practice the production of glass cabinet doors.
Step 1: How to Make the Door
I am planning to make the glass embed into the wood 20mm.
using table saw to cut this is an easy way
  1. Setup the blade height to 20mm
  2. Cutting the slot, using a jig to hold wood is more safe then hold by hand
  3. Cutting another wood with talbe saw crosscut sled
  4. Assembly and debug
  5. Glue it
Step 2: How to Make the Cabinet
  1. Use 15mm Yellow Pine to make boards
  2. Cut every edge to 45 degree
  3. Glue it
  4. Install the cabinet handle (holes distance 96mm)
  5. Install the hinges (should embed into the wood 1.5mm, attention the red circle)
  6. Stick rubber feet
  7. Finish
Thanks for watching.
