Homemade Spork/knife
Intro: Homemade Spork/knife
Since i have always wanted a spork but always found them too expensive. I thought let's make one myself
STEP 1: Thing You'll Need
-An old spoon
-A hacksaw an anglegrinder or a dremel
-a couple of needle files i used a round one and a halfround one
-a marker
-some sandpaper
-a marker
-some sandpaper
STEP 2: Design
Use the marker to draw out the design you want to make.
STEP 3: Sawing
First I used my dremel to cut it to length. Then I cut out the fork section of the spork. (Optionally you could use a round needle file to make a serrated section.) Then i filed the prongs of the fork to a sharp point and filed all the cut pieces round.
STEP 4: Sanding
I used sanpaper from 120-400 grit to smooth all the edges so i wont cut myself.
STEP 5: Washing
After i sanded everything I first washed it with regular dish soap and then put in the dishwasher to get it completely clean of any metal filings
STEP 6: Use It!
In the end it worked out really nicely and it was very easy to make. It's a great tool for camping because it's the only utensil you'll ever need and its pretty lightweight and durable. I hope you liked my instructable! Leave a comment if you have any suggestions
Cheers Laurens
Cheers Laurens
15 Comments
gm280 7 years ago
I like it. But this is more then a simple Spork. Seems it also has a serrated knife incorporated as well. So you have to change the name to accomidate the knife as well.
theeJuicebox 1 year ago
deluges 7 years ago
You could call it a sporknife
AlbertC80 6 years ago
runcible spoon
betterways 7 years ago
I have a set of vintage party sporks from the 50s or 60s. I like them & use them all the time at home. But I have a suggestion for better sporks. Put the serrated edge on the other side of the spoon so it will be away from your mouth when eating.
Scythedeus 7 years ago
maybe he's left handed =P
jonbutterfill 7 years ago
gpeterson10 7 years ago
Laurex2002 7 years ago
thanks for reading
thanks for reading
dwade9 7 years ago
I thought of that too but since my handle was pretty thick it would take too much time because i would have grind an edge on it and then use the files to make the serrations
Cheers laurens
cuttreetop 7 years ago
It look too dangerous for spoon use.
I know it looks dangerous but I made the serrated edge on mine not super sharp
