How to Make a Wooden Pipe
Intro: How to Make a Wooden Pipe
Wooden pipe has a unique taste at smoking, and for that in this instructable I will show you how to make a special one for yourself made out of simple materials and strong wood.
This wooden pipe was made in a professional way and carefully homemade.
For this gift you will need:
Materials:
- A thick piece of wood
- Stem of a pipe (that contains the filter)
- metal bowl
- optional: olive oil + white vinegar + lemon juice (that just to give dark color)
- ribbon for gifts
Tools:
- hand saw
- drill
- hand sander
- hole saw
STEP 1: First This Is the Intial Design
STEP 2: Find a Thick Piece of Wood
saw the piece of wood to the precise size of your pipe around 20/10 cm
STEP 3: Cutting the Initial Size
cut the piece of wood to the initial size of the pipe to be ready to the next step
STEP 4: Hole the Bowl
Using 29 mm hole saw and a drill make a hole in the center of the top side and be careful in this step to don't broke it
STEP 5: Drill the Air Way
using a drill and a 6mm bit make the air way to the center of the bowl
STEP 6: Sand It Carefully
After cutting it, sand using a hand sander the wood till you have that smooth touch
STEP 7: Color the Wood
As you can see the difference between the two photos, in the last photo I brushes it with a natural mixture made up of olive oil and vinegar and lemon juice which give me that dark color
STEP 8: Set Up the Stem and the Bowl
STEP 9: Decorate the Pipe
STEP 10: Test the Pipe
STEP 11: Ready to Present !!
STEP 12: Addition
Here I've added some beautiful wood pieces.
20 Comments
MadFerrum 5 years ago
Hassan Nasser 4 years ago
You can smoke with it without the bowl by coating a protection on the wood inside.
Thank you
gamer328 6 years ago
mark449 6 years ago
science x 6 years ago
hummer98 6 years ago
fadi928 6 years ago
varan890 6 years ago
rose3338 6 years ago
ali452 6 years ago
karim814 6 years ago
evan129 6 years ago
hulk0079 6 years ago
jhoncena101 6 years ago
iceng 6 years ago
Impressive, makes me want to make one too.. How log did it take you to make it ?
Where can I get that curved pipe stem with filter and how much was it ??
Hassan Nasser 6 years ago
Swansong 6 years ago
That looks beautiful, you did a great job :)
thanks a lot
