Homemade Laser Module
353,370
1,726
142
Introduction: Homemade Laser Module
About: I love electronics and all about DIY.
You all know that when making a laser device, the most difficult part it's focusing without buying a module.
So here it is, a complet guide about how to make a focusable laser module with parts you have lying around.
Everybody havs heared about aixiz module, but they're expensive, at least if you know you can do something similar for free.
This module is not recomended for laser diodes over 300mW, because lens can melt and it's not the best heatsink.
the goals I wanted to achieve are:
-Make it easily focusable.
-Make it with household parts.
-make it nice and durable.
I'm very happy with the final results, the module acts as heatsink and it can focus the laser to a single burning point or a beam.
Step 1: Materials
The parts you will need are:
-A 6v motor case (best from a dead motor).
-The lens from the sled.
-A 5mm (inner diameter) washer.
-Three long bolts for the motor case.
-Three ballpen springs (1cm).
-A laser diode (no more than 300mW).
Step 2: The Lens Mount
First of all, you'll need to open the motor and extract the rotor, the magnet and the bearing.
When you're done, cut three equidistant notches and round them to the bolts' diameter.
Then, pick the lens from the sled, and carefully put it in the washer hole. Glue it carefully to not drip glue onto the lens; any scratch or glue drop will disturb  the beam.
Step 3: Placing the LD
Solder the wires to the diode ans isolate them with some heatshrink tube.
Now yoh have to press the diode into the case. Inprovise a press and force the diode into the hole.
The hole is 5mm wide and the diode 5.65mm, so, maybe you need to enlarge the hole a bit.
If you add a bit of thermal grease, the heat from the diode will be dissipated better.
Finally, i added a golden brass cover that fits in the motor case and has a 4mm hole for the 3.8mm laser diode.
Step 4: The Bolt Focuser
Now the washer with the lens can move freely from top to bottom, so three springs will keep it while it still being adjustable.
The tree-bolt-adjustment can shape the beam or fix any lens deviation making possible to focus the laser in a single dot.
Step 5: Done!
Now you can save your money and recycle unused parts to make your own laser module for your next laser project.
Remember that this module is not recomended for diodes over 300mW because lens can melt and it is not a good heatsink (it's iron)
If you have questions or upgrade ideas, comment so all can learn about them.
If you like my project, please vote me for the I Could Make That and Weekend Projects Contests.
Runner Up in the
I Could Make That Contest
Be the First to Share
    • Hand Tools Only Challenge
    • Modify It Speed Challenge
    • Remix Contest
      Remix Contest
    142 Discussions
    Sailormanenzo
    Sailormanenzo
    4 years ago
    Could you please tell me how to make the driver?
    driver?
    And tell me
    xavierbarthies
    xavierbarthies
    Reply 6 days ago
    The driver is not made its recycled from a DVD or computer DVD drive
    xavierbarthies
    xavierbarthies
    Question 6 days ago on Introduction
    What power supply does it use, can use a battery pack or must I use a plug
    Luziviech
    Luziviech
    Reply 5 years ago on Introduction
    from a cd-driver - author has some other ible how and what to salvage from a cd driver
    xavierbarthies
    xavierbarthies
    Reply 7 days ago
    Can the sled be from a computer box dvd or is that not strong enough
    Chikoo D
    Chikoo D
    Reply 3 years ago
    You could have googled for sled. Anyway, here the sled means the DVD sled in which the laser diode and the lens are housed.
    0zzy
    0zzy
    5 years ago
    Somone commented about anyone getting injured by a burning lazer well i made one last year as part of an experment all went well until somthing in my garage fell over and it just happened to land on top of my burning lazer and pushing the button that switches the lazer on i was not in my garage at the time but the time i got back to my garage the lazer had set my garage on fire no one got injured but i lost half the contence of my garage costing me just under £8000 so yeah burning lazers ARE VERY DANGEROUS
    0m3rta13
    0m3rta13
    Reply 1 year ago
    Lmao! Awesome. Would’ve been a funnier story if it all burnt down
    systemwiz
    systemwiz
    Reply 4 years ago
    they can be, but ignorance is always dangerous
    GuyW12
    GuyW12
    3 years ago
    Your instructions show the lens as "from the sled" but I do not see where you tell us what the "sled" is. Can you define where the lens comes from and how we might find a similar item?
    abuhafss
    abuhafss
    Reply 3 years ago
    Chikoo D
    Chikoo D
    Reply 3 years ago
    thanks.
    ArifK41
    ArifK41
    3 years ago
    wow this is realy interesting but i want to know what kind of lens is used in this module, can we get them from optical store?
    abuhafss
    abuhafss
    Reply 3 years ago
    Arif Sb. the lens could be found in DVD drive's sled.
    RobertB497
    RobertB497
    3 years ago
    Nice work is it possible to make a laser cutter to cut 3 to 4 mm metal plate as it would make working with hacksaws, hole saws and files to cut a lot quicker and if a miss cut can ruin the job . I know I could make a bad cut with a laser but it be a lot of time saved making a new project
    Ryzler
    Ryzler
    4 years ago
    How do you vote? Just hit favorite?
    I like your projects, very resourceful.
    Tom French
    Tom French
    4 years ago
    Where do you get the lens from?
    sandoreduardo.pereyra
    Excelente !! También lo estoy intentando. Gracias por el aporte.
    u971
    u971
    4 years ago
    Now that's some good recycling right there,thanks for the idea.
